08-08-2012, 05:35 PM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
| Vp front link question
Dumb question... What is this silver piece in the picture and where does it go in terms of this link mount ? I can't find a picture that shows |
08-08-2012, 05:56 PM | #2 |
Rock Crawler Join Date: Feb 2008 Location: Golden Corral getting Fat
| Re: Vp front link question
it is the bearing adapter for the bigger bearing if your using the VP top case you can use a bigger bearing you need to use this if your not |
08-08-2012, 06:09 PM | #3 |
Ahhhh. Thanks |
08-08-2012, 07:05 PM | #4 |
Should the screws be blue locked tighted for vp parts??
08-08-2012, 07:12 PM | #5 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
| Re: Vp front link question |
08-08-2012, 09:40 PM | #6 | |
| Re: Vp front link question Quote:
I assume pushed into the housing so the loop faces outward because on the axle housing there should be a complimentary slot/groove to close the loop around the bearing, correct? | |
08-08-2012, 10:26 PM | #7 | |
Quarry Creeper Join Date: Jan 2011 Location: westminster
08-09-2012, 06:49 AM | #8 |
Shouldn't this push all the way in flush? I'm just a little worried about forcing anything... Want to ask first |
08-09-2012, 08:17 AM | #9 | |
Sent from my iPad using Tapatalk | |
08-09-2012, 08:32 AM | #10 |
Its the stock bearing I'm using... I didn't buy VP bearings.... the bearing seems to sit in the stock axle housing perfectly .... this silver beariing channel doesn't seem to want to sink any further in the link mount... kinda stuck where its pictured.... but if that is the correct way to put it in maybe I just need to apply more pressure to force it in further? This is why newbies buy RTRs ;) |
08-09-2012, 09:08 AM | #11 |
hmmm, tried the other link mount & it fell in as u said.... this first one must be crooked........ thanks for your replies
Vp front link question - Similar Threads | ||||
Front 4 link | Ant Chaser | Newbie General | 1 | 03-29-2011 01:50 PM |
4- Link front... | Pappy | Axial SCX-10 | 11 | 08-01-2010 01:09 PM |
Front 4-Link? | AK-Maxx | Axial SCX-10 | 4 | 04-15-2010 10:06 AM |
3 link front 4 link rear? | MaxxMc | Losi Mini-Rock Crawler | 7 | 04-03-2009 09:31 AM |
IFS w/ 4 link front and 3 or 4 link rear. | T-Man | Traxxas Crawlers | 6 | 10-26-2004 07:28 AM |
