09-12-2012, 06:13 AM | #1 |
Newbie Join Date: Dec 2010 Location: netherlands
| traxxas big bore
Hi I would like a set off traxxas big bore shocks use for me XR10 with the shock cap mod what springs can I use for this to shocks thanks |
09-12-2012, 07:03 AM | #2 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
| Re: traxxas big bore
You can use the Team Associated RC18T rear springs, or the Losi Mini-T front Springs. With some Jeepin Doug Spring cups, found in the vendor section. If running the stock chassis, stick with the 2661 or 2662 since you are doing the cap mod. 2660 will likely be too short. I think those are the part numbers, doing it from memory. |
09-12-2012, 07:25 AM | #3 |
ok what do you need big bore shock for a Chaotic Switch Carbon Bodiless Chassis with Axial XR10 axles and what is a good starting setup for the shocks oil and springs all info is welcome as it can with order numbers to misunderstandings to avoid it thanks |
09-12-2012, 08:27 AM | #4 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
K I have the same chassis and I run the traxxas 2660 shocks with the cap mod. I use pink mini-t front with 40weight and red mini-t rear with 45 weight oil. I also use the jeepin doug cup retainers. This set-up works good for me but the oil weight is mostly personal preference and alot to do with temperature. Also I am at 4lbs 8oz now so that is a factor aswell.
traxxas big bore - Similar Threads | ||||
traxxas big bore??? | bigemike | Axial SCX-10 | 1 | 08-21-2012 09:11 PM |
3.5 traxxas big bore | Grimreeper | General Crawlers | 5 | 04-29-2010 09:09 AM |
traxxas big bore? | theonek | Axial AX-10 Scorpion | 7 | 01-15-2008 03:06 PM |
