Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: BEC under SERVO
Old 09-15-2012, 03:35 PM   #1
Default BEC under SERVO
does anyone know of a specific thread that shows some good pics of the bec under the servo?? I have been searching for the last hour!!! I just cant seem to get mine to fit in there. Im about to get a bigger hammer cause i know others have been doin it forever now and im just behind the trend!! Any help would be appreciated guys. Thanks!!
001Hulk is offline   Reply With Quote
Old 09-15-2012, 04:07 PM   #2
Default Re: BEC under SERVO
My thread does its the t1e SS carbon chassis hopefully lightweight its on the first page of the xr thread
jeremyfowler33 is offline   Reply With Quote
Old 09-15-2012, 04:07 PM   #3
Nevermind....Bigger hammer worked....I think, Ill know for sure after I power it up!!
Old 09-15-2012, 04:08 PM   #4
Thanks for the respnse!!
Old 09-15-2012, 04:12 PM   #5
I asked the same question a little while ago, but I had already fit it. I used an older bec without the capacitor on the end. I made sure the blank fiberglass board was facing toward the motor. I did have to desolder and resolder the power wires to point the wires up toward the servo and I had the reciever wire wrapped back through the shrink tube going out with the power wires. I did cut the original blue shrink tube and redid it after the work. It was a really tight fit between the axle and the motor.
I don't have any pics at the moment, but I will be tearing my front axle apart to find a blown bearing from Nats. lol
Tydl is offline   Reply With Quote
Old 09-15-2012, 04:29 PM   #6
Removing the power cap did it!! After reading I realized my old bec didnt even have one so i cut it off. Thanx a bunch fellas!!
Old 09-15-2012, 07:09 PM   #7
Custom Carbon Fiber
Robbob's Avatar
My build shows mine. Did the same thing, clip the cap and been good ever since.
Sent from my EVO using Tapatalk 2
Robbob is offline   Reply With Quote
Old 01-24-2013, 02:00 PM   #8
Thats all you need. a bigger hammer and some duct tape.
DGuy is offline   Reply With Quote
Old 01-24-2013, 05:24 PM   #9
So no problem running it with no cap?
chevotafun is offline   Reply With Quote
Old 01-24-2013, 06:00 PM   #10
Cutting the cap or having an old one is the best. When I had my
Xr I did this mod it was called the jeep kid bec mod like over 2 years ago
Jeepkid is offline   Reply With Quote
Old 01-27-2013, 01:43 AM   #11
R_2
I also removed the top board from cc bec.. Its held only by some thermal tape on to the regulator and tight fitting hole onto the little cap on other end.
On top board there is little piece of aluminium tape supposed to act as heat sink.. but I think mine could be more efficient About beer can thicness aluminium glued with 2-compound thermal glue.
That extra tab wraps around the stock "servo plate", and added 2 little drops of CA to the ends of bec. I`ll try to remember to take more pics of it installed when I take the servo off next time..
R_2 is offline   Reply With Quote
BEC under SERVO - Similar Threads
Help with CC BEC to servo 99xjlove Losi Mini-Rock Crawler 18 04-29-2012 01:37 PM
Servo and Bec carp40 Electronics 6 06-18-2010 03:33 AM
Servo and bec?'s BeerMonkeY Tamiya Clod Buster 0 09-15-2008 09:19 PM
