04-24-2012, 08:33 PM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Grand Junction
| Help with CC BEC to servo
Okay So I converted to lipo and fried my stock servo. I now have a replacement and have bought a CC BEC and a Y harness. Do I only need to remove the red wire from the BEC Side? Is that the only wire to remove? Can't find any good diagrams of wiring just a Servo with a BEC using a Y harness.
04-24-2012, 09:46 PM | #2 |
Pebble Pounder Join Date: Apr 2012 Location: sa
| Re: Help with CC BEC to servo Last edited by a2hill; 04-24-2012 at 11:07 PM. |
04-25-2012, 07:16 AM | #3 |
So I need to run Just the Signal (red wire) from the Servo to the rx and The power and ground (Yellow and Brown) from the BEC?
04-25-2012, 06:41 PM | #4 |
C'mon guys I know most of you run a BEC! Do you run through the ESC or Direct to the SERVO?
04-25-2012, 06:58 PM | #5 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Help with CC BEC to servo http://www.castlecreations.com/suppo...user_guide.pdf BEC to Servo connector these might help and both of those were found in this link The beginers guide to the MRC. |
04-25-2012, 07:43 PM | #6 |
| Re: Help with CC BEC to servo got bored |
04-26-2012, 07:15 AM | #7 |
Thanks Hillbilly, I found that one last night. Actually I found about 20 different schematics in one thread. Here is the link to the thread in case anyone else needs to see some awesome Schematics. Definitive wiring diagrams for BECs Rx Servos Motors etc. |
04-26-2012, 07:56 AM | #8 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
| Re: Help with CC BEC to servo |
04-26-2012, 12:39 PM | #9 |
| Re: Help with CC BEC to servo Thanks for the advice Crash....... I searched for 3 days. Here, Google, and YouTube. Apparently that is the only thread on the subject and I had to word my searches 20 different ways to come up with it. Nice of you to come in after the question was answered and make such an awesome comment! Thumbs up to ya!
04-28-2012, 08:07 AM | #10 |
So I got everything connected the way that Hillbilly posted the drawing of. Won't work for me. I can plug in 2 known good servos and nothing. One will get the signal when u plug it in but then it won't turn. The other Nothing either way.
04-28-2012, 09:14 AM | #11 |
I also used a Y connector if that makes a difference
04-28-2012, 09:39 AM | #12 |
a picture might help.
04-28-2012, 11:12 AM | #13 |
K I'll post one in a few
04-28-2012, 12:03 PM | #14 |
Ok Here is an overview of the whole setup BEC to one end of the Y harness Male end of the Y harness with just the Center Signal wire attached and Servo connected to the other end of the Y harness Last edited by 99xjlove; 04-28-2012 at 04:31 PM. Reason: pictures |
04-28-2012, 12:16 PM | #15 |
Quarry Creeper Join Date: Apr 2011 Location: bay area
It looks like you don't have the signal (orange wire) connected into your esc. The orange wire should be plugged into the esc and only the orange one and what wire is out at the first connector of the y harness? The only wire that should be removed from the bec is the orange wire Sent from my DROIDX using Tapatalk 2 |
04-28-2012, 12:27 PM | #16 |
I removed the Middle wire. So the colors are red-middle, brown -Left, and Orange-right? I thought orange was yellow and Thought the middle wire was the signal? Now I know why I don't do wiring
04-28-2012, 12:33 PM | #17 |
Problem solved. Swaped red only for orange only! Thanks Motakitty!
04-28-2012, 08:51 PM | #18 |
Your welcome, glad to help Sent from my DROIDX using Tapatalk 2 |
04-29-2012, 01:37 PM | #19 |
best thing i've found!- Holmes Hobbies / Holmes Bikes :: Servos accessory/ Voltage regs :: RX Bypass Adapter no need to unplug the wire from your esc to the rx either! simply plug the servo and BEC to the plug, and plug the adapter in your servo channel on rx and you're off crawling! |
Help with CC BEC to servo - Similar Threads | ||||
Servo without BEC | dano104 | Electronics | 2 | 04-22-2009 06:23 AM |
Servo and bec?'s | BeerMonkeY | Tamiya Clod Buster | 0 | 09-15-2008 09:19 PM |
New servo and BEC? | SukiCrawler | Electronics | 5 | 07-31-2008 06:11 PM |
