10-21-2012, 12:53 PM | #1 |
Newbie Join Date: Jan 2008 Location: Loveland
| Power Issue
I've dropped in and asked a few questions, got some great help on this kit and building it. I've got a decent knowledge of building, wiring and programming R/C, however I've hit a problem I can't get past. Here is the build sheet XR10 Bone stock Dual Holmes Hobbies hand wounds Spektrum RX Castle BEC Single Tekin FX-R Pro Funky dig switch I've previously received help for here. Battery choices are 3s 1350mAh 20c/ 3s 1250mAh 45c and some 2cell lipos as well. JR 9100T servo HERE IS THE PROBLEM...... I've taken it for a couple test runs. @ about 30-45 seconds, it acts as if it is hitting the voltage cutoff while turning or working the servo hard. When I switch batteries and try again, I get the same result. I believe I have the Speed control programmed properly. I have it set to Zero voltage cutoff now to try and narrow the problem down. I have the Castle BEC set to allow an output of only 5.1V now. No idea where to go from here. I'm going to go through the programming of the speed control again, but I'm out of ideas. That's why I'm here. Short version. truck acts as if it's hitting the voltage cutoff with full batteries and correct programming. WTF? Last edited by Posterchild; 10-21-2012 at 01:50 PM. |
10-21-2012, 01:22 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: U.S.A
| Re: Power Issue
remove the dig switch from the picture... process of elimination.. see if problem continues... thats what i would do... good luck man...
10-21-2012, 01:38 PM | #3 |
| Re: Power Issue
Bump your BEC to 6.5v. At 5.1v there isn't much room for the radio to operate, so any dip in voltage from the BEC will brown out the spektrum.
10-21-2012, 01:53 PM | #4 |
| Re: Power Issue |
10-21-2012, 01:59 PM | #5 |
| Re: Power Issue
I Would think depends on what servo you have. If ur servo can take 7.4v, you can go that high.
10-21-2012, 06:28 PM | #6 |
| Re: Power Issue
Are the batteries good? I.e., do they run a different vehicle OK?
10-21-2012, 06:39 PM | #7 |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
| Re: Power Issue
Is your BEC grounded to the RX?
10-21-2012, 09:04 PM | #8 |
| Re: Power Issue |
10-22-2012, 05:57 AM | #9 | |
| Re: Power Issue Quote:
Since you're direct to the RX, then yes, you're grounded. Does the ESC stop or does everything die? (when it dies, does the steering still work?) If it's the ESC, is it or the motor hot? | |
10-22-2012, 06:13 AM | #10 |
| Re: Power Issue
Batteries are good, I've tested them in my Losi Comp with no issues. When it stops working, the whole rig quits. No steering, no forward/reverse, no dig. |
10-22-2012, 09:00 AM | #11 | |
As mentioned, I think you need to raise your BEC output to 6+ volts, maybe 6.5 volts. Do you have any Tamiya or "cheap bullet" connectors in the rig? You may be losing power there. Also double check soldered connections, you may have a poor one (maybe battery to ESC?) that gives up under load. | |
10-22-2012, 09:37 AM | #12 |
Quarry Creeper Join Date: Jan 2011 Location: westminster
| Re: Power Issue |
10-22-2012, 01:43 PM | #13 |
| Re: Power Issue Ah, yes it is.. I looked twice an didn't see it in his parts list.. yep, same as my 8711.. So did you raise ur bec yet? Cause I'm having a similar problem.. but not everything shuts down.. my steering just stalls at full lock in a bind.. but my 7950 is 7.4v.. so I'm pretty sure the bec voltage deff needs turned up from the 6, I think, its set at now. |
10-23-2012, 10:10 PM | #14 |
| Re: Power Issue
OK. Just raised the BEC voltage to 6V then to 6.4V just to make sure. Same end result. I don't like how the stupid posts are designed on the ESC to solder to. I've checked and double and triple checked the connections. They look fine. I'm going to swap the RX next, and go from there. Maybe even the servo next? This stupid thing is driving me nuts. Just to get things clear on another issue as well. My BEC connections are as follows. red/black leads are soldered directly to Deans battery connector RX lead is intact and is plugged into the "bind" slot on my RX. Same way had done it in the past with other crawlers. Last edited by Posterchild; 10-23-2012 at 10:19 PM. Reason: Extra clarification?? |
10-24-2012, 06:07 AM | #15 |
| Re: Power Issue
Do you have another free channel to put the BEC into? I remember some older BECs had problems putting the spektrum RXs into bind mode.
10-24-2012, 06:28 AM | #16 | |
Could I build a splitter, and piggy back another channel? ie. something I can build or buy that I can connect both the BEC and maybe the third channel to and plug it into the AUX port on the RX? | |
10-24-2012, 06:33 AM | #17 |
| Re: Power Issue
Yes you could do that. Or take out whatever you have on the Aux channel for a bit.
11-04-2012, 09:41 PM | #18 |
| Re: Power Issue
UPDATE** Hadn't had any time (or ambition) to test many theories and come up empty handed again. That said! With all of your help and a couple accidental stumbles around the site... SUCCESS!!!!!! I made one of these, So far, so good! Thanks again for all the advice. It is an older Castle BEC so that very well could have been my issue trying to run it through the bind slot. I suggest this trick for sure! Now I can devote more time to my scaler KOH buggy! |
Tags |
voltage cutoff, wtf? |
Power Issue - Similar Threads | ||||
Is the Tekin B1R "low power in reverse" issue fixed? | GWEEDZ | Electronics | 3 | 05-27-2011 12:50 PM |
Thunder Power 1350mah 2S balance issue | Jslick | Electronics | 3 | 07-24-2010 09:27 PM |
Rear power issue? | lildjloop | RC4WD Bully | 5 | 01-22-2010 10:59 AM |
Losi Lipo Works On Flight Power/Thunder Power Balance plate?? | fa1rch1ld | Electronics | 0 | 01-18-2010 11:46 PM |
Tlt modified power issue | phishead1101 | Tamiya TLT Crawlers | 2 | 09-28-2004 06:20 AM |
