11-03-2012, 01:11 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| **HELP** Dual ESC's F'd Up. Whats the problem?? - YouTube Whats wrong, i jumper cabled up all my wiring before i soldered to check to see if it would work first, tried to be smart about, and don't know whats wrong! Its like the escs dont start moving at the same time. help me please. Last edited by MiniMorris; 11-03-2012 at 01:13 PM. |
11-03-2012, 01:15 PM | #2 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: **HELP** Dual ESC's F'd Up.
You need to calibrate both ESC's to your radio at the same time. Its a tricky process but can and must be done. Secondly, you need to make sure your motors are set at 0* timing. If at that time both ESC's are calibrated identically and motors are at zero and the problem still exists you can increase the timing or decrease the timing to get both motors in sync. A good set of matched motors will eliminate the motors being at fault. |
11-03-2012, 01:23 PM | #3 | |
| Re: **HELP** Dual ESC's F'd Up. Quote:
11-03-2012, 02:53 PM | #4 |
My micro sidewinder won't calibrate, I plug in my battery turn it on while holding full throttle, and I get all 3 lights to flash a couple times then 1 red flash and then only yellow and green , all in 2 secs. , yellow and green flash every sec. Until I unplug battery.
11-03-2012, 09:22 PM | #5 |
Quarry Creeper Join Date: Jan 2011 Location: westminster
Change the software version |
11-03-2012, 11:02 PM | #6 |
11-04-2012, 12:22 AM | #7 |
| Re: **HELP** Dual ESC's F'd Up. |
11-04-2012, 01:52 PM | #8 |
Pebble Pounder Join Date: Jun 2012 Location: Canada
Make sure you have a fresh battery. I tried this with a battery that was triggering low voltage cutoff, and it drove me insane...
11-04-2012, 03:16 PM | #9 |
| Did you have problems calibrating also because I'm following the guide in the manual and I'm getting led patterns not even close to what the manual says.
11-04-2012, 06:51 PM | #10 |
Led's just sort of made no sense.
11-10-2012, 09:39 PM | #11 |
| Re: **HELP** Dual ESC's F'd Up. DSCN0949.mp4 video by photobucketposting | Photobucket I got motors to start at same time but rear motor is slower by about 15%, i changed to v3.2 (i think) calibrating actually work like it said it would in manual. also i should mention esc settings are exact same. what could it be? |
11-10-2012, 11:16 PM | #12 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Check the timing of both your motors to see if they are off at all. Also check the TH and AUX EPA's on the radio to see if they are off from each other.
**HELP** Dual ESC's F'd Up. - Similar Threads | ||||
Dual esc's | THE CRAWLER KING | Electronics | 10 | 03-04-2011 07:14 AM |
Dual Esc's | Rimmshot | Redcat Crawlers | 2 | 03-21-2010 10:14 AM |
wiring diagram for dual esc's, dual servos, bec, and one battery??? | jedsled | Tamiya Clod Buster | 6 | 11-13-2008 07:36 AM |
Dual esc's | drcooper | Electronics | 11 | 07-21-2008 02:52 PM |
dual ESC's | jevyguy | Electronics | 3 | 11-17-2007 06:41 PM |
