11-21-2012, 08:26 PM | #1 |
Quarry Creeper Join Date: Mar 2012 Location: Montreal
| Chaotic Switch build "ESPER"
Hi all, I ordered the Switch in march but got an accident and droped the ball as I couldn't move one arm (getting too old for hill bombing on a long board obviously). Long story short, surgery, physio and starting getting better. I finally completed the order a month ago. I spent the summer reading your amazing builds, witnessing the great support from Chaotic and Chaotic Drivers, and while this is my first build and I am still inexperienced in the crawling scene, felt confident I could go somewhere solely based on all the insights and support found here (Not many cats crawling around here). This is now "The ESPER" I will not detail every steps as there are already many amazing thread on switch builds and I don't think I can really ad something new. Anyway, a quick shot for the Chaotic wiz regarding my link/shocks placement (As a starting point, I'll finally go crawling this weekend). Here is however the "shopping list" Mecanics:
électronique:
For now I am using VP DHII, I also have a set of SLW with Shaved Donas, however, I have planned to have Santa bring me D-lux or Vanquish knuckle weights. I am waiting for the vanquish tower links (in the mail from Chaotic). All on, the build is 5.7 pounds with 3 slugs front. With the SLW I should drop to 5.1 (my objective was 5.5 so I am quite happy). Clearance is 3 1/8th front of the plate, 3 1/4th rear of the plate. Shocks are modded big bores, limited to 3.5" front and unlimited in the rear (3.8"). Weight balance is a 3 milimeters out front of the plate side screw. I am always looking at ways to "repay" the amazing people and content found on RCCrawler. I am a french speaking person, so I decided to bring as much of the knowledge I find and compile from here and translate it. I made a full How To on Big Bore mod (in french yes HOWTO - Big Bore Mod pour XR10 And also a very detailed build thread, trying to provide not only the how to but also the "logic" behind it. Build Chaotic Switch "ESPER" (Xr10) I know this is not much but as many in this forum have spent time helping me getting up to speed, I felt that this knowledge has to be spread. Anyway, I'll keep on reading and asking and share one circle further. A gazillion thanks to all, especially to Chaotic (whom have been more than patient, thanks for your trust) and Chaotic Drivers. Time to eat some rocks! BTW, ESPER comes from Blade Runner Esper Photo Analysis - YouTube |
11-21-2012, 08:34 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: dartmouth ns
| Re: Chaotic Switch build "ESPER"
Looks really good, man. I see we have the same sponsor... Team Wallet!!! |
11-21-2012, 08:38 PM | #3 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
links look good man . i didn't see the VP front an rear link mounts in there , although there not necessary they help a bunch an i recommend them. I'm also not a fan on the big bores but to each an his own. I'm a big fan of the scx alum shocks but Marc run the big bores an loves them . this truck will do nothing but impress you . |
11-21-2012, 08:41 PM | #4 |
Hi Slowride1, The link mounts are in the mail from Chaotic. Quick question to you, I read top hole for front and before top hole for rear on the link mounts. Would you recommend a basic (starting point) placement for uppers to chassis once hooked to the link mounts. Can't wait to ride her! |
11-21-2012, 08:42 PM | #5 |
an here is the thing i dint like about them shock, i run mine lower than you do but i like my shocks rite where you have yours all but i run the top set of holes . not everyone likes the same setup for sure but that truck will work like that for sure
11-21-2012, 08:43 PM | #6 |
| Re: Chaotic Switch build "ESPER" |
11-21-2012, 08:43 PM | #7 |
leave them rite where you have them my friend |
11-21-2012, 08:44 PM | #8 |
11-21-2012, 08:45 PM | #9 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
What advantage do you get from running the vp link mounts Randy?
11-21-2012, 08:47 PM | #10 |
better link angles
11-21-2012, 08:51 PM | #11 |
seems like moving the front or rear make more of a change than moving them on the chasis to me an it also dosnt slam the links togather so the hit when you are tring to get more bit like it would if you moved the links at the chasis. most guy evan shit the front mount higher like 2 mm evan . i dont have mine shimed yet but i sure have thought about it really hard
11-21-2012, 08:59 PM | #12 |
Rock Crawler Join Date: May 2010 Location: Belfield NSW Australia
nice choice of rig mate :thumbup::thumbup: Sent from my GT-I9300T using Tapatalk 2 |
11-21-2012, 11:32 PM | #13 |
RCC Addict Join Date: Jan 2009 Location: O.C
Looks good man! The link placements are right on as are the shocks. Like slowride, I use SCX shocks but others have made the Big Bores work. So I got a little lesson from Del Monte this past Saturday while running some courses. Moving the Upper links in the VP mount affects a couple of things- 1. The lower the mounting position, the less axle steer you'll get. Basically meaning the axle will stay centered more when articulating instead of diving underneath one side or the other. It's kinda one of those visual things so sorry if it isn't to clear from my explanation. 2. The lower the mounting position, the more "unloading" you'll get from steep climbs. This might require a bit more weight on the knuckles to counteract the unloading tendancy. Congrats on the new rig and update us as you test it out. |
11-22-2012, 08:26 PM | #14 |
OK... I couldn't wait and went playing in the driveway... temperature outside is 40F... no tuning, crappy camera so sorry about that. I am just... flabbergasted... ESPERFIRST - YouTube |
11-22-2012, 09:34 PM | #15 |
looks like a good start
11-23-2012, 12:17 AM | #16 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Chaotic Switch build "ESPER" Quote:
Edit: I did. I did. I did saw a putty tat. Here's my answer from the other thread that this was asked in. You guys are making my brain hurt. The main reason most of us go to the VP upper link mount is for better mesh & overall rigidity of the transfer gear vs main gear. Thats the most common fail area. The mount DOES offer a couple more link positions which DEFINITELY helps to tune yer rig but a tuned rig with broken gears doesn't crawl very well. So Randy's answer is PARTIALLY right but you can easily get away with running a stock link mount IF they offered the same durability & strength that the VP pieces do. J.D. | |
11-23-2012, 12:22 AM | #17 |
Besides your cab being on backwards & your front shocks being upside down...you have a decent start. I can't stress this enough...ya GOTTA tune your rigs to YOU. Meaning your drive style, your terrain, your rigs weight, bias, power etc. You have some good jumping off points but you'll notice that most of us are CONSTANTLY changing things & trying new link or shock positions. Ya gotta find that happy balance but the serious compers are never satisfied & we're always chasing that better setup. J.D. |
11-23-2012, 01:13 AM | #18 | |
Gold Star Baby! Join Date: Jan 2011 Location: SOUTH JORDAN, UT
11-23-2012, 08:48 AM | #19 | |
Absolutely I heard that loud and clear I will compare that to Nitro. When I started what saved my life a couple time while I was learning how to tune a mill was "the factory setting". Thing is that I need a "basic ground" to start from. The idea is not about copying another rig, it is about having an average start and go from there. Eventually getting back there if things get out of hands. So many parameters to look after, If I start with something "stupid" it'll just be a neverending loop of frustration. At least, I can revert back to a safe place even though not optimal, and start again. I only wish I had a seasoned driver to hang out with, not only for the settings and "you should try this", but also for the driving Again thanks all, time to go out and crawl (and tune I promise). | |
02-20-2013, 03:59 PM | #20 |
Hi All, still buried under metric tons of snow in here (just had an additional 6inch today...). VP Mount Links are installed, I played with it indoor, but without rocks and this rig efficiency, hard to have a ton of fun. However, I have a quick question. Back of the chassis is hitting the upper links when stretching. Links finaly can "pass by" but this gives a real bump to the rig when it passes over it. Has anyone of you dealt with this? Would it be OK to lightly dremel the end of the chassis (behind shock mount) to round it a bit and allow bind free mouvement? Thanks in advance! Can't wait to go out and play! |
Chaotic Switch build "ESPER" - Similar Threads | ||||
AREA 51RC "Project Chaotic "Switch" XR10" | D19er | Axial XR10 | 105 | 03-10-2014 05:30 PM |
...Chaotic Switch........ "The Wicked Tuna" | Chaotic Crawlers | Axial XR10 | 165 | 03-29-2013 05:54 PM |
2012 berg "switch" build | ROLANDROCKSHOP | EnRoute Berg | 27 | 02-26-2013 08:30 AM |
Paystin's Chaotic "Switch" | paystin | Axial XR10 | 154 | 11-14-2012 05:54 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
