06-19-2012, 08:27 AM | #1 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| 2012 berg "switch" build
here goes my berg build ive been waiting to get going on.. chassis.. chaotic crawlers cf "switch" w alum hardware Chaotic Switch Bodiless Carbon Chassis elec.. 2x micro sidewinders/cc bec 2x hh 21t *ordered* hitec 7955tg servo 3s lipo 800-100mah 25-30c battery suspension.. Ti links chaotic berg links scx or big bores alum ball joints tires/wheels.. rovers/boss claws/sedona's/khaos mayhem evo's axles.. CCD berg tubes 300m 3rd gears rc bro's 7075 lockers drilled main gears Ti hulksta rear shafts*have to order* ?? Vp berg cvd's..fingers crossed..?? dlux servo mount and rear link bdw motor savers vp knuckles and weights ... ..... Last edited by ROLANDROCKSHOP; 06-22-2012 at 06:58 AM. |
06-19-2012, 08:35 AM | #2 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
| Re: 2012 berg "switch" build
Looking good |
06-19-2012, 08:43 AM | #3 |
It looks like a pile of parts that need to be put together. |
06-19-2012, 08:52 AM | #4 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
sounds good so far |
06-19-2012, 09:10 AM | #5 |
yep... im ready to get it together and tune it for next season.. ill be taking the dremel to the gear cases and rounding the edges a bit. |
06-19-2012, 11:27 AM | #6 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
parts and chassis looks real nice!! now get that thing together!! |
06-20-2012, 01:01 AM | #7 |
Nice pile of parts you got goin there bud Lookin forward to it |
06-20-2012, 11:49 AM | #8 |
got my gear cases stripped of anodizing... and then brushed with a wire brush on my dremel.. mounted my servo mounts from dlux.. attached the rear dlux link to the case.. rcbro's 7075 lockers ready for install.. im taking my time on this build.. i think im gonna go with the Ti hulksta rear shafts,instead of the axlemaster's. |
06-20-2012, 11:56 AM | #9 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
Looking good Josh!
06-20-2012, 12:00 PM | #10 |
| Re: 2012 berg "switch" build Nice pile of parts! Just an FYI it is highly recommended to use Red thread locker on the shiny new pieces. Mine are done that way and have never come apart. If you need to break the seal, bake the gear and locker at 450 degrees for 20 mins and carefully handle the hot part to break the thread lock.
06-20-2012, 12:08 PM | #11 |
im using some blue hobbytown loctite... it holds like red but its a bit easier to break loose. the screw has nice crisp snap when it lets loose. when i worked at hobbytown i gave a few to some customers to get their input and they liked it better than the og loctite..and they were using it on their 500 class heli's. but thanks for the info dickyT! if it does endup failing ill go with some red for shure. |
06-20-2012, 03:02 PM | #12 |
thought id throw a weight pic in the mix.. no guts..just cases/tubes and what you see.. front..5.39oz rear..4.38oz i found some RED alum screws for the cases too.. |
06-20-2012, 03:09 PM | #13 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
looks good man what did you give up on the xr |
06-20-2012, 03:13 PM | #14 |
| Re: 2012 berg "switch" build |
06-21-2012, 09:31 PM | #15 |
I wanna be Dave Join Date: Oct 2007 Location: 801
I have been excited to see this build happen for a while now. You might push me over the edge and force me to build a berg. |
06-21-2012, 09:42 PM | #16 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Looking really good Josh about time you built a berg |
06-22-2012, 05:48 AM | #17 | |
| Re: 2012 berg "switch" build Quote:
might as well.. i think this will be my 3rd one ive built up... but those are no where near the lightweight sexyness this one will have.. waiting on ittybitty to get restocked on those sexy Ti hulksta shafts.. if we could only get someone to make us some lightweight gears for these axles.. that would be the shiz.. | |
06-22-2012, 09:10 AM | #18 | |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
DLUX can mill your gears for you and mod the pin for a larger size. Check our 53 Willys build thread. | |
06-25-2012, 10:40 AM | #19 | |
if all else fails ill hollar at dlux and have him mill me a set..thanks pdog! go my Ti steering links in today.. mounted my lockers to the gears.. all this waiting is killing me.. | |
07-05-2012, 10:35 AM | #20 |
update... got my chaotic Ti links in and installed.. HR red alum ball joints.. steering links made up and installed.. more to come as parts come in.. weight as of now..1lb 3oz .. Last edited by ROLANDROCKSHOP; 07-06-2012 at 01:40 PM. |
2012 berg "switch" build - Similar Threads | ||||
My "Frogger" build "Litoria xanthomera" | DRV KRAWLER | Axial AX-10 Scorpion | 61 | 10-04-2011 09:09 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
1st berg build "BERGLAR" | ROLANDROCKSHOP | EnRoute Berg | 40 | 01-12-2010 11:56 AM |
"DiEzel's BeetleJuice Berg build" | DiEzel | EnRoute Berg | 30 | 08-01-2009 05:01 PM |
"Holy Roller" Mrs. Cruzin Illusions Berg Build | Cruzin Illusion | EnRoute Berg | 61 | 03-16-2009 07:19 AM |
