01-13-2013, 01:44 AM | #1 |
Quarry Creeper Join Date: Aug 2012 Location: Melbourne
| Ant's XR10 Build
Hey fellas. Ive been on RCC for some time now and before I start I have to thank everyone on here for all the info I have obtained! You guys are legends and have helped me with all sorts of info! So here it is... Front Axle: VP Knuckles VP C-hubs VP Motor plate VP trans case VP Ti steering rod VP Servo armour Robitronics servo horn Rowdy Racing axle mounted battery plate with custom guard (upgrading to the RR product soon!) Axial HD spool More HD gears to come CVD's to be upgraded also. BWD motor Savrs Rear Axle: VP Lockouts VP Motor plate VP trans case M-R screw mod Axial HD spool More HD gears to come BWD motor Savrs Chassis & Suspension: Stock XR10 chassis (will be upgrading shortly) VP Ti lower bent links VP Ti Upper bent links Traxxas Big Bores Mini - T springs Shock cap mod also done Dougs Cups Wheels: Switching between stock Axial XR10 wheels (narrowed) with Boss Claws and Axial Rockstar 2.2s with Rovers on them. VP foams in the BC's Custom brass wheel weights fitted to XR10 wheels Electronics: Dual FXR setup Team Brood machine wound 45t Intensity motors Hitec 7955tg servo Airtronics MT-4 1300mah Lipo I am still very new to crawling in general but I'm loving the XR10! I do find that when I'm crawling in my usual spot that the boss claws dont give me the same grip as the rovers. However I find switching the tires over between the XR10 wheels to be a nightmare so until I buy some wheels from Tomy (who has been so helpful in my Noobishness) I'm not going to stress too much. I do try not to use the Rockstars too much as they give the truck a crazy wide stance which I do not like! Front Axle Never realised how much steering throw I was missing out on until I got this bad boy! Rear Axle Running shots And here is the RTR weight.....yeah she needs a diets BIG TIME which Im hoping the new chassis and wheels will drop a few grams Im open to any tips you guys can give me as Im still learning alot about crawling! So any advise will be taken on! Let me know what you think! Anthony |
01-13-2013, 06:41 AM | #2 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: Ant's XR10 Build
Looking good so far. I know it's strange at first going from the Rover's to a pin tire. They definitely handle different. Try cutting out every third row of pins to help with the hook up or make your own pattern. I know of a few guys in my club that swear pins don't work, but I switched to Rover/Blocks and so far I don't plan on changing them back to my Rovers.
01-13-2013, 07:11 AM | #3 |
RCC Addict Join Date: Feb 2008 Location: Nevada
Those servo horns are the shit too, I bought mine a year ago and hammer it bad! still holds up Good looking XR10 |
01-13-2013, 07:14 PM | #4 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
Nice rig man, how you like them motors, just got a set of the same exact ones last week and just installed them tonight but have not got a chance to see how they work, just ripped around the living room floor to make sure everything worked.
01-13-2013, 08:25 PM | #5 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
looks like one hell of a start an only thing to update is chasis an links man |
01-13-2013, 11:00 PM | #6 |
| Yeah they seem really smooth! Previously I ran a pair of Integy 55t until one popped a wind but these seem much nicer.... Considering they were cheaper than the integys!
01-13-2013, 11:01 PM | #7 |
01-14-2013, 11:12 AM | #8 | |
01-14-2013, 11:15 AM | #9 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Ant's XR10 Build Which chassis did you get? His regular one or the LaaLaa Special? Tomi is a great guy to work with and I'm sure you will be very happy with the quality of his chassis looking forward to seeing it together |
01-14-2013, 11:27 AM | #10 |
tomi chasis looks sweet for sure . i have his weight holders an im very happy with them so im sure you will be happy with his chasis |
01-14-2013, 04:37 PM | #11 |
Rock Crawler Join Date: May 2011 Location: Cali/Korea
Looks good buddy, Try running the claws on the rear and the rovers on the front. We run that combo all the time in Korea and its a pretty awesome combo. lik |
01-14-2013, 07:20 PM | #12 |
01-14-2013, 07:22 PM | #13 | |
I'll be buying some of his designed weights through Rcbros shortly and some new wheels from Tomy too. Just waiting for the funds >| | |
01-14-2013, 07:38 PM | #14 |
just remember when its bound up just stop an pull it out instead of tring to drive it out . a repo is 5 points an a broke truck cost money an ends the day |
01-17-2013, 03:50 AM | #15 |
01-17-2013, 03:53 AM | #16 |
So I was able to take the rig out tonight for a pack. I modified the chubs to clock one notch back and it's made a massive difference in vertical pulls. How many notches can I go back before its not worth it? |
01-17-2013, 10:39 AM | #17 |
Truthfully, its hard to tell, it would benefit more to roll ur front axle back.. its hard to tell in the pics but it looks rolled forward a bit. If you move ur upper links back at the chassis till ur servo is close to level, ur chubs will prolly be clocked back too far then..
01-17-2013, 11:19 AM | #18 | |
01-17-2013, 11:40 AM | #19 |
I always like a level servo myself.. it will help a good amount. It will also help get ur horn up out of the dirt an hanging up on the rocks as well.. Edit.. did ya get them tires shaved yet? That with rolling ur axle back, you shouldn't have any issues with getting into ur links or shocks with ur inner tire.. |
01-17-2013, 02:09 PM | #20 |
when the servo sits flat is where you want your upper links to be . as far as where is to far to roll the chubs back, look at the truck from the front an you will have to watch an see where the tie rod hangs down . by moveing it to far you will get it[the tierod] where it hangs to low an will hang up on everthing one hole past what u can get is about all i have heard of people running |
Ant's XR10 Build - Similar Threads | ||||
Ant's XR10! | Abrown83 | Axial XR10 | 12 | 08-29-2012 02:29 AM |
first build XR10 | salmonarmdingo | Axial XR10 | 6 | 09-02-2011 11:03 AM |
first xr10 build | drpuffmd | Newbie General | 6 | 07-14-2011 10:59 PM |
My XR10 Build | jhaggerty | Axial XR10 | 11 | 06-04-2011 03:13 PM |
my xr10 build | booher26 | Axial XR10 | 3 | 02-13-2011 09:47 AM |
