Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Sourdough's Rock Spider Re-Build
Old 05-25-2013, 11:32 AM   #1
Default Sourdough's Rock Spider Re-Build
Here is the start to my rebuild, truck fully disassembled and ready to clean up!
I'm over here at the CreationFab shop today, so I'm going to do my best to give live updates as we make progress!
TOM
sourdojack is offline   Reply With Quote
Old 05-25-2013, 01:28 PM   #2
Default Re: Sourdough's Rock Spider Re-Build
My smashed up BRXL's with CC BEC
Chris went to town on milling my gears to shed some serious grams!
I made new lower links out of 3/16" aluminum 7075 rod to replace the Ti links.
I ran the lathe by hand to cut the threads to 10-24.
New carbon tube for upper links. 4.8mm tube and I drilled the rod ends to 3/16".
Old 05-25-2013, 01:33 PM   #3
Chris got the gears finished up!
Stock Axial HD locker:
Lightened by CreationFab:
Stock 36t Gear:
Lightened:
Old 05-25-2013, 01:53 PM   #4
I decided to ditch the Ti Cab for the Carbon version
Also had Chris lathe down my rear Ti shaft (rear axle has the "front axle mod")
for a 3x8 bearing. My front axle has the bigger VP bearing upgrade and a steel shaft since I snapped my Ti one at a comp.
Old 05-26-2013, 12:59 PM   #5
Nice to see the rebuild has begun Tom
jonbo21 is offline   Reply With Quote
Old 05-26-2013, 10:42 PM   #6
The new bearing for the rear axle is 3mm wide compared to the stock 2.5mm. So I had to break out the dremel and clearance the bearing pocket.
Old 05-28-2013, 10:08 AM   #7
I got the axles put back together yesterday... Nothing too exciting there, new bearings and fresh grease.
Got the chassis bolted back together, and all the links clearanced in the right spots late last night and took a quick picture.
Old 05-28-2013, 10:25 AM   #8
RCP CRAWLERS
ZoSo's Avatar
nice build ....chassis looks great
ZoSo is offline   Reply With Quote
Old 05-28-2013, 11:36 PM   #9
Thank you! Are you coming to Arizona next weekend?
I got my electronics figured out tonight and was able to put my 2 Holmes BRXL ESC's and hobbyking RX on a Rowdy plate. The Castle BEC is going behind the servo. And 450Mah CheapBatteryPacks on the front axle, 3S or 4S depending on my mood I guess...
Old 06-03-2013, 10:54 AM   #10
I almost forgot to post up pics of the sweet Shift Hubs that I won!
Huge thanks to BC Brian, and they fit perfect with my RcBro's knuckle weights.
My steering works great with my RcBro's 6mm extended steering arms too!
Huge thanks to FreqE for making sweet skinz for my trucks and radio!
Old 06-03-2013, 11:58 AM   #11
TSK
Shelf queen
TSK's Avatar
Cool mod to the rear transfer geaer shaft
**edit** I swear I saw something similar before. And I think it was EGRESSor. Awesome none he less.
TSK is offline   Reply With Quote
Old 06-04-2013, 04:04 PM   #12
Hey Sourdough,
Glad you like the Hubs. They look mighty fine on your rig.
BC-Brian is offline   Reply With Quote
Old 06-04-2013, 06:57 PM   #13
Y-Town Crawlers
Del Monte's Avatar
Yep
Boca sells a 3x8x2.5mm bearing that will work without any case mods. I've been running them since not long after I saw EGRESSor's and they have held up great.
Del Monte is offline   Reply With Quote
Old 06-05-2013, 09:15 AM   #14
Yeah I saw it on egressor's build also (that guy is pure genious!)
I got the panels all finished, wiring finished and actually drove it on some rocks last night. Now tonight after work I have to pack everything up and us Northwesterners are headed down to AZ for the shootout.
Hope see a bunch of you guys there!
I brought it with me to work today to get it shined up
Old 06-05-2013, 09:36 AM   #15
Nice work on the truck, it looks bad ass. Not to kiss ass but I feel its the best looking XR I have seen. I was lucky enough to drive the truck and it drives great. I really like what you did with the upper links. I cant believe how much weight you lost with that, plus the money you saved. Its a win win. Make sure to represent the Oregon boys in AZ
Beerman Crawler is offline   Reply With Quote
Old 06-09-2013, 11:35 PM   #16
The truck drove really well this weekend in AZ! I aced the first 3 courses and by lunch I was sitting at a -90. I made some major mental mistakes and didn't finish the last two courses But I had a great time and us PNW represented for sure! Can't wait to crawl in AZ again
I really enjoyed meeting people and putting faces to screen names haha
The truck help up great BTW, my only carnage was a broken roof that happened off course, and flat tire
TOM
Old 08-02-2013, 07:44 PM   #17
How do you mount the rod ends to these carbon links?
THanks
sally1800 is offline   Reply With Quote
Old 08-03-2013, 09:36 AM   #18
Yes, explain how you do that please... and by the way, what's the name of that chassis ? Who makes it ?
CrawlrKing is offline   Reply With Quote
Old 08-05-2013, 01:43 PM   #19
I just used some clear 2 part epoxy from the hobby shop (still holding up great!)
The name of the chassis is the "Rock Spider" it was designed by Fallout. And unfortunately, not available any more. RcBro's will be selling the new version of this chassis very soon though!
TOM
Old 08-18-2013, 07:38 PM   #20
Some pictures of Tom at the comp today
Will photo bombing Tom
Sourdough's Rock Spider Re-Build - Similar Threads
Sourdough's SuperSport Truck sourdojack Axial AX-10 Scorpion 145 12-10-2015 06:26 PM
Sourdough's No Name Truck sourdojack Axial XR10 49 11-06-2011 06:30 PM
The Spider Build Going Up! Tamiya TLT Crawlers 15 11-15-2007 05:25 PM
Spider Monster Rock Crawler????? shocker Newbie General 17 01-11-2007 03:28 AM
