05-28-2013, 08:20 PM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Concord, NC
| Tie Rod Help
I wanted to upgrade my steering on my XR10 so I did the tie rod mod. I bought a second axle and modified the bottom piece (cut off stock slide) and installed the motor, c-hubs and knuckles. I clocked the c-hubs in the full back position. Everything went great. I then installed the tie rod and there is something wrong. The wheels do not line up properly. It seems like the tie rod is too short. I measured the rod and from end to end (no rod ends included) and it was 4 7/8 inches. The rod included the revo rod ends. Or, and this is a very real possibility, I installed it wrong. See the pics below to see what I'm talking about. If anyone has any advice or a fix for this I'd really appreciate it. Thanks! |
05-28-2013, 08:23 PM | #2 |
Yeah, that's WAY too short
05-28-2013, 08:26 PM | #3 |
Newbie Join Date: Jul 2012 Location: British Columbia
| Re: Tie Rod Help
Looks like the wrong tie rod, when you order you need to get the one for the particular steering knuckles on your truck. Had this happen to me!
05-28-2013, 08:26 PM | #4 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Re: Tie Rod Help
Homie you gonna have to have a longer tierod. Chaotic Crawlers has a buy and bolt in piece that will save you a bunch of time Axial Steering Tierod |
05-28-2013, 08:34 PM | #5 |
| Re: Tie Rod Help
Damn, you guys are quick! Thanks for the answers and that's what I was afraid of. Looks like I'll be ordering some more parts |
05-28-2013, 08:57 PM | #6 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: Tie Rod Help
The one Chaotic selling is for Vp Knuckle OR axial knuckle, look like you has the axial one, just make sure you choose the right one....
05-29-2013, 09:29 AM | #7 |
| Re: Tie Rod Help
Which tie rod did you buy? Was it the VP version? Never thought I'd see one of those Level 3 "diff guards" here on RCC |
05-29-2013, 09:33 AM | #8 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
| Re: Tie Rod Help
That's certainly not a tierod for an XR10, VP or otherwise. Almost looks like a link as short as it is. This is the one you need: Axial Steering Tierod Make sure you select the correct one for your knuckles (Axial or VP). If you've clocked the hubs, you want straight. Last edited by Wicked Monkey; 05-29-2013 at 09:36 AM. |
05-29-2013, 09:37 AM | #9 | |
| Re: Tie Rod Help Quote:
05-29-2013, 10:01 AM | #10 |
| Re: Tie Rod Help I put a thread in the Wanted section on here and someone answered it. He said it wasnn't specifically for the XR10 but that he used it on his XR and it worked. I am going to try a different set of rod ends that he sent with the tierod, but I'm afraid it's still gonna be too short. What's the deal with the diff guard? I saw it on ebay and I thought it would be a good addition, try and save some wear on the axles.
05-29-2013, 10:04 AM | #11 | |
05-29-2013, 10:05 AM | #12 |
| Re: Tie Rod Help |
05-29-2013, 11:10 AM | #13 | |
Also, longer rod ends aren't going to get you there. And the longer you go on the ends, the more of a weak point you put in the steering. | |
05-29-2013, 11:35 AM | #14 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: Tie Rod Help |
05-29-2013, 11:40 AM | #15 | |
05-29-2013, 11:42 AM | #16 |
| Re: Tie Rod Help This is where I was going with my 1st post. I was wondering if it was a VP link that would have come with Revo and Jato rod ends. Even though it's not I'd recommend trying the Jatos. If you could measure the difference between the length you are at now EYE TO EYE versus what it needs to be to get the knuckles pointed straight we could tell you if the Jatos will fix the problem. Jatos aren't a problem with the steering links as much as with suspension links. |
05-29-2013, 11:58 AM | #17 |
| Re: Tie Rod Help
Needs a good inch at least...
05-29-2013, 12:39 PM | #18 |
| Re: Tie Rod Help
I'm gonna check when I get home, i think he sent some additional rod ends in the package and see if they work. But it's all a moot point though, I went ahead and ordered the tierod from chaotic crawlers. Thanks for all of the help everyone!
05-29-2013, 07:28 PM | #19 | |
Sent from my ADR6425LVW using Tapatalk 2 | |
Tie Rod Help - Similar Threads | ||||
Tie rod wire? | saltinemadness | Losi Micro-Rock Crawler | 6 | 11-12-2012 04:52 AM |
Tie-rod question | tuf-gmh | Axial XR10 | 9 | 07-14-2012 10:15 AM |
KK high clearance tie-rod vs. CKRC OTA tie-rod vs. ?? | BigB_117 | EnRoute Berg | 64 | 07-06-2009 11:20 PM |
