03-08-2014, 08:52 AM | #1 |
Rock Stacker Join Date: Sep 2013 Location: Sandy
| First MOA question
Just got a XR10 roller, and i have it temped together with a single ESC no dig (till i can get a 2nd ESC) and when i go up my plywood/carpet ramp the front tires spin before the rears, its exact same gearing front/rear. i know this is because the rear tires have more load on them and require more voltage to spin. My question is will dual esc's fix this? or is this just the way it is with a MOA?
03-08-2014, 09:10 AM | #2 |
Newbie Join Date: Jan 2013 Location: SLT
| Re: First MOA question
Dual escs will fix that. With one esc its common to want the front to over speed the rear,this way the front helps pull the truck over. If the rears spin first it tends to want to flip the truck on its lid. Welcome to MOA and lets see this puppy. |
03-08-2014, 09:40 AM | #3 | |
| Re: First MOA question Quote:
also i tried going up it backwards and same thing the rear tires spun easier then the fronts | |
03-08-2014, 09:54 AM | #4 |
With dual escs and proper mixing you can mix in or out under/overdrive. you could even make the fronts spin clockwise while the rears spin counterclockwise. Weight transfer is a large part of moa. You may be lifting the front of the truck due to shock and link geo set up. Search squat anti squat. Good luck and have fun. |
03-09-2014, 02:54 PM | #5 |
Pebble Pounder Join Date: Feb 2014 Location: italy
2 esc and radio that allows mixing with function-specific MOA (I use the sanwa mt4) and see how it changes ..
First MOA question - Similar Threads | ||||
Moa vs shafty question | Dezertdirt | Newbie General | 20 | 08-04-2013 11:03 PM |
Moa question | Dezertdirt | Newbie General | 1 | 07-29-2013 05:11 PM |
DX6i MOA Question | rcrawler13 | Electronics | 6 | 02-29-2012 03:51 AM |
MOA question | ToyZuki | Scale Comp Rules | 46 | 09-10-2011 09:46 PM |
moa bastard jr question | mattstang | Axial AX-10 Scorpion | 1 | 11-07-2009 04:52 PM |
