Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: I want to get back to crawlin.
Old 01-15-2017, 03:29 PM   #1
Default I want to get back to crawlin.
A few years ago I built an XR10 With aftermarket everything and loved it but for some reason sold it. I'm looking at buying a used XR10 and a used Futaba 4PLS is this a good radio for front and rear dig ability and is there still quite a bit of aftermarket support for these rigs. I'll want a different chassis and links. Thanks in advance for any direction you all can point me in.
Andrew
knuckleBuster is offline   Reply With Quote
Old 01-15-2017, 03:47 PM   #2
Default Mr
Andrew
The aftermarket for the XR10 is great. Don't have any input on the Futaba. I watched e-bay and they do show up ever so often. I lost 2 bids on 1 that I wanted, thank goodness!! I found a new sealed kit and won it. Just finished at Christmas and today was its maiden voyage. I had a hard time getting it like I wanted, but this forum helped a lot! Here's a link to my thread and found a small problem today but I'm sure I'll get it straightened out by spring time! Good lock!
M2 Dig ESC setup help.
White cobra is offline   Reply With Quote
Old 01-15-2017, 03:47 PM   #3
snapon boy's Avatar
Default Re: I want to get back to crawlin.
Mt4 airtronics and a homebrew mistress chassis!
149 r/c worx Team Driver
snapon boy is offline   Reply With Quote
Old 01-15-2017, 04:22 PM   #4
Default Re: Mr
I'll start reading build threads and thanks for your input. I need to know more about your username. I have a white 94 Cobra I bought brand new.
Old 01-15-2017, 04:25 PM   #5
Scalerfab.com Team Driver / 149 r/c worx Team Driver
I used a 4PL on my first build and have a line on a barely used 4PLS locally so I would like to snag it. I believe it's just a newer model of what I had.
Old 01-15-2017, 06:39 PM   #6
Default Mr
My user name is the car I drive. A 1997 white Mustang Cobra I bought brand new. Its been in my hometown parade 4 times now.
Old 01-15-2017, 06:43 PM   #7
That's cool. We both bought our Snakes brand new. I show mine about 4 times a year.
Old 01-18-2017, 11:56 AM   #8
Stock up on gears! They are getting hard to get
SDheavymetal is offline   Reply With Quote
Old 01-20-2017, 01:26 PM   #9
^are they really getting hard to get where do you order yours from @sdheavymetal
Foxracer11 is offline   Reply With Quote
Old 01-22-2017, 05:40 AM   #10
Hal
The gears are still available from HR as is the big bearing gearbox the price is not bad either. The hardest part for me to find is the rear axles and the top shaft for the front axle. 49 mm long I believe, not the 58 mm long rear one.
Hal is offline   Reply With Quote
Old 01-22-2017, 06:07 AM   #11
Hal
About the radio, I don't know much about the Futaba but everybody in our club runs the Airtronics (Sanwa) MT4 it's a real easy setup for dual ESC. The controlls are good also. It has a lever right where your left thumb sits to controll the front/rear dig. It's also proportional so you can set more or less power to one end, not off or on. I run a front axle in the rear because it' a much better design' don't have to do 2 bolt mod and less spare parts to stock. It takes all the same parts as the rear axle. The only mod are to one of the axles. You have to trim one of the tangs where it goes in to the gear. Good luck.
Old 01-22-2017, 12:37 PM   #12
I advise others to stay away from the XR because part support isnt what it used to be. They can be stout but it takes alot to get there and many of those parts are unavailable.
Curcal is offline   Reply With Quote
Old 01-22-2017, 05:31 PM   #13
I'd build a berg instead of an xr10.
tapped-out is offline   Reply With Quote
Old 01-22-2017, 08:05 PM   #14
Either build a bully2 or a berg , xr stuff is to hard to track down now.
As for the radio grab the 4pls it is the new 4pl.
chevotafun is offline   Reply With Quote
Old 01-22-2017, 11:11 PM   #15
I used Axial, RC4WD and Hot Racing gears. I think you can only get Hot Racing gears now.
I'm running a RC4WD Bully2 front and a Dlux rear axle(berg).
Old 01-23-2017, 03:09 PM   #16
No idea what I'm doing
I have a brand new set of Vanquish/RC4WD/FastEddy loaded XR axles sitting in my bins for this very reason. Only assembled (no screws) for pictures. I don't run them just in case I need parts.
C*H*U*D is offline   Reply With Quote
I want to get back to crawlin. - Similar Threads
DMG Stiffy Kit: Long Back or Short Back DrDiff952 Axial Wraith 0 01-14-2014 09:48 PM
crawlin back in.. bigmike07 Georgia 4 04-12-2013 09:41 PM
coming back to crawlin.... slowlearner Axial Wraith 6 08-20-2012 10:34 PM
getting back into crawlin scarecrow Newbie General 5 11-05-2010 11:32 AM
Gettin back into crawlin again Zack.anderson08 General Crawlers 8 10-20-2010 08:04 PM
