11-05-2014, 05:23 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: San Jose
| Battery Options
What batteries are you guys using? I need to pick up some more battery packs but most of what I've found exceeds the 43mm width of the battery trays.
11-05-2014, 06:23 PM | #2 |
Newbie Join Date: Aug 2013 Location: Tacoma
| Re: Battery Options
I'm running Venom 25c 4100mah 2s and they fit great. Just ordered 2 turnigy 2s nano-tech 5000mah. Specs say they'll fit.
11-05-2014, 06:42 PM | #3 |
Quarry Creeper Join Date: Sep 2006 Location: nor cal
| Re: Battery Options
SMC 5000 40c..hard pack, it fits and im getting about 20 min of run time. very happy with them.. 25 bucks ea.
11-05-2014, 07:47 PM | #4 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: Battery Options
What ever you end up getting, just make sure it's a minimum 25C.
11-05-2014, 07:56 PM | #5 | ||
| Re: Battery Options Quote:
Keep me posted, all the 5000mah's were too wide at 49mm Last edited by derycksan; 11-05-2014 at 09:28 PM. | ||
11-05-2014, 09:22 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
| Re: Battery Options
Both of these fit well... 3s - https://www.rpphobby.com/ProductDeta...tCode=DTXC1867 2s - https://www.rpphobby.com/ProductDeta...tCode=DYN5303T |
11-05-2014, 10:40 PM | #7 |
Newbie Join Date: Oct 2014 Location: Earth
| Re: Battery Options
Can any one confirm if these will fit? Factory Spec 7.4V 9400mAh 60C Traxxas I already have a set of them that I run in my Summit. And have already pre-ordered another set for the Summit, but it would be great if they fit the Yeti XL as well. Any one have a link to where I can look up the specs on the Yeti XL battery compartment size? Thanks. |
11-05-2014, 11:57 PM | #8 |
| Re: Battery Options
Battery tray dimensions: Length:6.89in(175mm) Height:1.3in (33mm) Width:1.7in (43mm) From the horses mouth (axial's site) |
11-06-2014, 12:59 PM | #9 |
Pebble Pounder Join Date: Dec 2007 Location: Tucson, AZ
| Re: Battery Options
More options Axial, Yeti XL Packs |
11-06-2014, 04:03 PM | #10 |
| Re: Battery Options |
11-06-2014, 08:54 PM | #11 |
Pebble Pounder Join Date: Jan 2013 Location: Fall River
| Re: Battery Options
I'm still waiting for my yeti xl to arrive since it is still in back order status but from what i have read in a different forum, those battery tray dimensions have a weeeeee bit of wiggle room. i hope they do cause the batteries i have left over from a summit i sold are 45mm wide. According to axial, that's about 2mm to wide. We shall see. If they do fit, than these are good batteries to get SPC LiPo Power, Lithium Polymer (LiPo) Battery Pack; 8200mAh, 50C, 2S, 7.4V Soft-Case |
11-12-2014, 07:08 PM | #12 |
Pebble Pounder Join Date: Mar 2014 Location: Raleigh
| Re: Battery Options
I have 8000 mAh 40c 2s and 5200 mAh 50c 3s packs that will be here in another week and a half and you won't have to mortgage your house to buy them. They are guaranteed fit and come with a 1 year warranty**. 8000 mAh 40c 7.4v Yeti XL LiPo Battery Pack 5200 3s 50c Yeti XL LiPo Battery Pack **Warranty against manufacturers defects. Failure caused by damage or misuse is not covered. |
11-13-2014, 04:09 AM | #13 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: Battery Options
I'm using 2 of these Turnigy nano-tech Ultimate 7500mah 2S2P 90C Hardcase Lipo Pack (US Warehouse) one on each side, and they fit with room to spare. I ran it wide open for 25 minutes (yes, full gas, in a 30 acre field, didn't stop) and the motor was only 90deg, the esc cold, and the batteries were still asleep when I took them out. Very nice batteries. Giant bullets on the pack, pre-angle soldered wires, and nicely made hard cases. |
11-13-2014, 03:39 PM | #14 | |
Quarry Creeper Join Date: Sep 2011 Location: NW
11-13-2014, 06:50 PM | #15 |
| Re: Battery Options
The spc batteries i posted earlier are more bang for your buck IMO
11-13-2014, 09:51 PM | #16 | |
So after test fitting my batteries that I have that use to be for my old summit, I can definitely say that there IS wiggle room in these measurements from axial. The battery that I have is 46mm wide and fits perfect and axial says 43mm wide is the max. Just an FYI out there for people needing to shop for batteries | |
11-15-2014, 06:22 AM | #17 | |
Newbie Join Date: Nov 2014 Location: France
Excuse me for my bad english but i am french ..: Oops: did you try the battery Factory Spec 7.4V 9400mAh 60C Traxxas in a yeti? the dimensions 're good? Thanks Ronald | |
11-15-2014, 10:11 AM | #18 |
Pebble Pounder Join Date: Apr 2013 Location: West Fargo
| Re: Battery Options
if the max amps are fitting, then I would say the SMC version will assuming the dimensions posted for both are correct. Curious as well, as well as the runtime people are seeing too. |
11-15-2014, 09:59 PM | #19 |
| Re: Battery Options
I got 25 minutes non stop field action with mine. A super hard long run. The charge put back in 6850mah, so the cutoff setting is conservative.
11-25-2014, 10:12 PM | #20 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
| Re: Battery Options
How much height wiggle room is there? I just ordered and I think the packs I ordered are to tall!!!
Battery Options - Similar Threads | ||||
battery options | gefitt | Team Losi Comp Crawler | 5 | 04-07-2012 09:30 PM |
Battery tray & battery options? | Mysterious | Axial XR10 | 10 | 02-18-2012 01:13 PM |
battery options | geotracker7000 | Losi Mini-Rock Crawler | 1 | 01-12-2012 05:47 PM |
Battery options? | 09xD | Duratrax Cliff Climber | 7 | 07-15-2009 10:12 AM |
Battery options | crawlmaxx | Electronics | 6 | 02-21-2005 09:41 AM |
