12-01-2014, 09:35 PM | #1 |
Newbie Join Date: Nov 2014 Location: Reno, NV
| Diff Shim Question
I took the front bumper of the car apart in order to access the differential so I could replace one of the bearings that blew up. I figured since the front portion was apart I would attempt to install the shims behind the pinion gear up front. Can I take the gear out from this side? If so What needs to be done in order to install the shim from this point? Or do I need to access the gear from the other side where the drive line is attached?
12-01-2014, 09:37 PM | #2 |
Pebble Pounder Join Date: Feb 2009 Location: wilkeson
| Re: Diff Shim Question
When you take the cover and diff out there will be 3 1.5mm screws that hold the pinion in. Remove those and the whole thing slides out threw the front.
12-01-2014, 09:38 PM | #3 |
Same for the rear.
12-02-2014, 10:00 PM | #4 |
Rock Stacker Join Date: May 2011 Location: tenino
And I thought I was the only one to blowup a carrier bearing.. I got 15 minutes out of the box before it gave out and stripped out the r/p.... But with one call to axial they shipped me new parts....Great Product support... |
12-02-2014, 10:13 PM | #5 |
I put all the shims in and completely went threw it before I even fired it up. My pinion mesh was WAY to tight to!! I knew I was taking a chance by running 6s right off the bat!!!
Diff Shim Question - Similar Threads | ||||
Can someone show me or tell me how to Shim the pinion in the diff, thanks | milestone | RC4WD Trail Finder 2 | 12 | 04-02-2014 06:27 AM |
Question About The Diff | gernade | Axial AX-10 Scorpion | 1 | 06-28-2012 10:03 AM |
Axle shim question | Creepy Crawler | Team Losi Comp Crawler | 0 | 11-01-2009 12:04 PM |
how to shim x factor diff ? | robo-3 | XTM Crawler | 2 | 02-07-2006 07:16 AM |
