Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: Trophy Truck
Old 01-23-2015, 05:37 PM   #1
Default Trophy Truck
Here is the direction I'm headed with my XL. I think the tire look close enough to the Baja TA. Thoughts? Advice pros cons? Any input welcome. Thanks
ednerin is offline   Reply With Quote
Old 01-23-2015, 06:03 PM   #2
Default Re: Trophy Truck
Nice is that from an HPI Baja.
Barndog Racing is offline   Reply With Quote
Old 01-23-2015, 06:06 PM   #3
Hey Barndog yep those are the stock front 5T tire HPI 4437 I used the soft foams grey HPI super stars and I'm undecided on the color beadlocks to use waiting to get my body back. It would be kewl if HPI could get the licensing to put the BFG Baja TA logos on instead of the HPI stuff maybe Axial could get it done?...
Old 01-23-2015, 06:15 PM   #4
That would be sweet you are in Mtn . Home I'm in Meridian.I want to get the kit after I sell my Yeti jr.
Old 01-23-2015, 06:26 PM   #5
Where do you run at?
Old 01-23-2015, 09:35 PM   #6
I just moved here recently so haven't been out much.
Old 01-25-2015, 11:07 AM   #7
check out the hpi rodeos on TR-10 wheels. looks like a grooved baja TA on method beadlocks. would look tits on one of these.
BMOC is offline   Reply With Quote
Old 01-25-2015, 03:16 PM   #8
Looks good! I like the wheel set up I may have to pick something like that up.
exokiler is offline   Reply With Quote
Old 01-26-2015, 10:43 AM   #9
heading in the right direction it looks like.
what body are you going to use?
sj4x4 is offline   Reply With Quote
Old 01-26-2015, 11:36 AM   #10
Stock body for now with a wicked body wrap from Darkside Studioarts!
Axial Yeti Monster Buggy XL Wrap Graphics "Hell Ride" Fits Body Parts 1 8 | eBay
Old 02-12-2015, 04:12 PM   #11
Just a little update, I like it! LMK; now to figure out a better shock set up, LST style or wait for the dual rate kit springs to hit the street.
Some DHawk goods
Old 02-16-2015, 10:37 AM   #12
Little bit of carnage nothing major but product support has hooked me up.
Left front pin coming out
Right front is OK for now
Old 02-16-2015, 05:30 PM   #13
I was starting to get scared that you never drive the thing!
Money Pit is offline   Reply With Quote
Old 02-16-2015, 05:36 PM   #14
I Ain't skeert!
Old 02-17-2015, 08:20 PM   #15
Love the spare tire look. Do you know what axial screw numbers are used to mount the tire carrier?
mitemluh is offline   Reply With Quote
Old 02-18-2015, 06:35 AM   #16
Looks AWESOME!
How did you mount the HPI rims onto the yeti? I don't have mine yet to see what it takes.
JLOC is offline   Reply With Quote
Old 02-18-2015, 08:27 AM   #17
Part tree AX31013 has the items required and the screws are here...
Page 42 Step 63
http://docs.axialracing.com/instruct..._4WD_-_Kit.pdf
Old 02-18-2015, 08:42 AM   #18
Originally Posted by JLOC View Post
Looks AWESOME!
Here is what I used drilled the center to 8mm
HPI 102530 ALUMINUM WHEEL HEX HUB SET 24mm (GRAY/4pcs)
There is also these not sure of the quality or fitment and they would probably add too much stress to the already small axle carrier bearings.
Integy 24mm Hex Wheel 4 Hub 6mm Offset for Traxxas 1 10 T Maxx Revo | eBay
Old 03-01-2015, 02:49 PM   #19
Well I guess 6S was too much....
Old 03-01-2015, 05:28 PM   #20
I almost wonder if it would be a good idea for the after market comes up with a stronger gear setup. heat treated perhaps.
Trophy Truck - Similar Threads
Rc trophy truck desertmaxx Non Crawler RC's 18 09-08-2010 07:09 PM
sc/trophy truck foxposi_150 Non Crawler RC's 8 09-05-2010 11:43 PM
Trophy Truck VS Stadium Truck? KROGOTH Chit Chat 14 08-21-2009 09:18 PM
Trophy truck Mnster Non Crawler RC's 10 06-04-2008 04:27 PM
Cr-01 Trophy Truck! axelsnapr Tamiya CR-01 11 06-02-2008 09:33 AM
