06-16-2015, 09:32 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Receiver box question
Finally got all electronics installed. All that is left is to link esc to radio. I am building the kit and there is a rubber grommet that slides in a groove in the receiver box for all the wires. I can't make it work with all the extra wires (y-harness for ebec and motor and esc fans). I only bash dirt no water will it be a problem not using this Grommet or seal?
06-16-2015, 11:01 PM | #2 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Receiver box question
It will not be an issue. just be careful if you're around water. You could always use silicone sealer around the wires to keep the moisture out if you get nervous.
06-16-2015, 11:01 PM | #3 |
Rock Stacker Join Date: Apr 2015 Location: Thomasville
It will just allow dirt into the reciever box. Should be fine
06-16-2015, 11:27 PM | #4 |
| Re: Receiver box question |
06-17-2015, 12:32 AM | #5 |
Hog out the section a little and cut a 1/4 grommet in half for a little more room or just wrap your wires in as much electrical tape as needed to cover the hole as best you can. Not 100% WP but it will be 99% dust proof.
06-25-2015, 08:34 PM | #6 |
Rock Stacker Join Date: Feb 2015 Location: San Leon
The connections on the Y harness do not need to be in the enclosed area, just spray some corrosion x or some grease in the plug and then plug it back together so it will not corrode. Another note of mention that many may miss or not think about is drilling a weep hole or two under the servo so the water drains in that area, the rest is a bath tub in its self...
Receiver box question - Similar Threads | ||||
ESC and receiver in the same box | xCoolHandLukex | Electronics | 2 | 12-05-2012 11:40 PM |
Shortcut to receiver box | avoidsthelight | Axial Wraith | 11 | 07-28-2011 04:14 PM |
who's using traxxas receiver box? | chicostaxxs007 | General Scale Talk | 6 | 07-02-2011 10:57 AM |
Trying to get the receiver out of the receiver box | rock-gobbler 77 | Electronics | 6 | 03-03-2011 03:03 PM |
slash receiver box | callahanc83 | Axial SCX-10 | 9 | 06-24-2010 04:14 PM |
