08-15-2015, 10:01 AM | #1 |
Newbie Join Date: Jul 2015 Location: Tacoma
| Hub pin lost. Replacement ordered. Any DIY options in mean Time?
Title kinda says it all. I lost a Hun pin and ordered some brass replacements but was looking for a DIY option to get it up running at this time. Any help would be great. Thank you Doug
08-15-2015, 10:36 AM | #2 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
| Re: Hub pin lost. Replacement ordered. Any DIY options in mean Time?
A small piece of #12 wire like from a fence should work. Don't tighten the grub screw too much. Also, you could buy a small drill bit that fits perfect and use a cut off wheel to cut the non fluted end off to length. tighten the grub screw as tight as you wish. Lock tight the grub screw either way. Sent from my SM-N900V using Tapatalk Last edited by Motorider; 08-16-2015 at 07:09 AM. |
08-15-2015, 12:30 PM | #3 |
Thanks so much. That's the kind of info I was looking for. Sent from my iPhone using Tapatalk |
08-16-2015, 01:27 AM | #4 |
Pebble Pounder Join Date: May 2015 Location: Baton Rouge
I'm actually using a heavy duty body pin right now on mine. Running 6s and have made 4 or 5 runs with no problems. Just take bolt cutters or a dremel and cut to size.
Hub pin lost. Replacement ordered. Any DIY options in mean Time? - Similar Threads | ||||
axle pin fell out need replacement | A DOG | Losi Mini-Rock Crawler | 5 | 03-12-2010 04:07 PM |
Lost Pin from Drive Shaft | domer | Losi Mini-Rock Crawler | 13 | 11-13-2009 07:57 PM |
lost drive shaft pin quick fix | crawlinlosi | Losi Mini-Rock Crawler | 1 | 06-30-2009 08:38 PM |
