01-23-2016, 09:55 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| PROOF aluminum front bulkhead is mandatory
New stock bulk head, new gears, new bearings, all shimmed properly. This is after 3 packs today in dirt. Just started grinding so i thought it ate the gears. Melted housing and pushed pinion out. I remember some one posted abot the front getting too hot and softening the plastic. Bearings are free no binding. Glad I have new DHAWK bulkhead and HD gear sets on the shelf. |
01-23-2016, 10:00 PM | #2 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
| Re: PROOF aluminum front bulkhead is mandatory
It's a feature. Easy access to your bearings. Dhawk is Dshiznit. |
01-23-2016, 10:06 PM | #3 |
Boy do I feel like a you know what. Look at the top pic and you will see it. Only thing I can figure is a defect. The bearings both turned when i took the pinion out but after looking at the pic I posted and seeing that bearing I went back and inspected it and it is busted. Oh well live and learn. Wierd thing is they were all new with only 3 packs on em.
01-24-2016, 01:56 AM | #4 |
Newbie Join Date: Oct 2015 Location: New Albany
This is what happened to mine. The plastic ring was up near my tranny. I had no idea where it came from untill I tore it all down. What a money pit.
01-24-2016, 06:45 AM | #5 |
Pebble Pounder Join Date: Apr 2008 Location: Mtn Home ID
| Re: PROOF aluminum front bulkhead is mandatory |
01-24-2016, 02:02 PM | #6 |
AVID bearings. This is the first time in my 4 years of using AVID that I don't have an answer for the failure. Usually its dirt and plain ol use. But the bearing is 1.00 and I already have the DHAWK bulk head and HD gear set so not that big of a deal.
PROOF aluminum front bulkhead is mandatory - Similar Threads | ||||
Dhawk aluminum front bulkhead!! | Priv Joker | Axial Yeti XL | 76 | 01-13-2016 07:10 PM |
Dhawk bulkhead with Hotracing front front sway bar | mond | Axial Yeti XL | 7 | 09-19-2015 08:44 AM |
Aluminum Front Bulkhead | Rcdood | Axial Yeti | 7 | 05-18-2015 03:46 PM |
