03-01-2015, 08:02 AM | #1 |
Quarry Creeper Join Date: Aug 2007 Location: El Dorado Hills Ca
| FastEddy Bearings 15mm Diff shims for the Yeti XL
Due to the massive requests, we are having the proper 15mm Shims made for the Yeti XL diff. We ordered them in about 2 weeks ago and got notice they have shipped. They will be posted here with a link when they arrive. We will offer them alone and also as a combo package with our Yeti XL bearing kit. Many people have tried to order the 15mm clutch shims we have for the Losi 5ive DO NOT ORDER THEM they are the wrong size and will bind up your diff. We have also ordered in the pinon shims but they will take much longer. Soon, soon, soon........ |
03-01-2015, 08:25 AM | #2 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
| Re: FastEddy Bearings 15mm Diff shims for the Yeti XL
Awesome Ed I will be ordering that stuff too you the man!
03-04-2015, 01:57 PM | #3 |
Quarry Creeper Join Date: Oct 2009 Location: northeast ohio
I will be too! and probably the bearings at the same time
03-05-2015, 06:27 PM | #4 |
Newbie Join Date: Mar 2013 Location: Missouri
I'll be ordering these as soon as they are available.
03-05-2015, 06:59 PM | #5 |
Quarry Creeper Join Date: Sep 2014 Location: pacific northwest
Can anyone comment on what this helps specifically for the kit version. thx
03-06-2015, 06:00 AM | #6 |
Rock Stacker Join Date: Feb 2015 Location: San Leon
The gear going into the dif box needs two shims on both to obtain a better "mesh of the gears. I ran without them for a little while but I installed them this week in the front and I can see the wear from not having them, I'm only running 2S. I can't find the other shims that were in the RTR box, I believed that I used them on my 8ight 3.0 E Truggy. So if he would hurry up and come off of these so I can add one more to the front and then do the rear I will feel a whole lot better. Just a FYI before I get asked the "mesh" was probably at 50%, meaning that the gear mesh that was in constant contact was on half of the gear facings, in laymen's terms, "bad"... Also note of mention when you reinstall the front end don't get the screws mixed up or they will poke out the housing.... Yes I know, FAIL.... |
03-08-2015, 10:58 AM | #7 |
Any new from Ed yet on the shims.
03-10-2015, 10:29 AM | #8 |
Yea, any word yet?
03-10-2015, 11:49 AM | #9 |
Rock Stacker Join Date: Mar 2015 Location: uk
Which shims are we talking about here? The 15x18x0.2mm AX31269 pinion shims or something to pack out the diff slop in the bulkheads? The bearings on the diff are 10x16x5mm AX31201. A 10x15mm shim here would be too large, no? Stands a chance of rubbing on the bearings outer casing. If you want to remove diff slop and move the 32T bevel gear into a better mesh then a 10x12x0.1 or 0.2mm shim would be the correct one. See HPI-Z892 or Z891 Last edited by fornowagain; 03-11-2015 at 02:33 PM. |
03-11-2015, 02:02 PM | #10 |
Fast Eddy isnt very fast on replying
04-16-2015, 03:33 PM | #11 |
Pebble Pounder Join Date: Apr 2008 Location: Mtn Home ID
Bump any news on these shims? |
04-16-2015, 05:53 PM | #12 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
C'mon Ed, give us the goods!! If you need a tester, I bet I can break it LOL |
04-20-2015, 07:14 PM | #13 |
Rock Stacker Join Date: Mar 2015 Location: Mahopac
15+ 6S packs through this kit. Built the diffs out of the box with three 15x21x4 bearings and a few extra fast Eddy 15mm shims on the pinion gear. Just pulled the front and rear diffs out for inspection and they are mint. Been bashing, high speed street racing, crawling and circle track racing. I'm glad to say this setup rocks!
12-26-2016, 09:39 PM | #14 |
Newbie Join Date: Dec 2016 Location: boone ,nc
Hello I know this post is older but i have got used yeti xl and needs all bearings replaced and would like to shim my diff too is there a direct link to what is needed? If someone could point me to the bearings i should go with eddy bearings? Id like to run 6s through mine but right now i dont want to even roll it across the floor lol rust inside bearings and im cleaning everything i can and want to replace grease,diff fluids ect and want the best i can do with the yeti xl rtr
12-26-2016, 09:56 PM | #15 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
As far as diff shims do the BHB mod on the pinion and get the aluminum spacer from DHAWK racing off ebay. Avidrc.com for the bearings I have been using their stuff for years and love em. I use the 1 dollar bearings in everything except the trans where I run ceramic. As far as diff fluid I run 200K front and 500K rear.
12-27-2016, 07:12 PM | #16 |
pro mod steve thanks very much ill look into doing that, barber basher mod? avid worked great for my 150+mph runs so thats good.https://www.youtube.com/watch?v=cROa...lh5xkmpsvrbk04 |
FastEddy Bearings 15mm Diff shims for the Yeti XL - Similar Threads | ||||
Yeti XL Bearing kit FastEddy Bearings | FastEddy | Axial Yeti XL | 15 | 10-15-2015 04:09 PM |
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
Yeti XL Blooper Money Shot FastEddy Bearings. | FastEddy | Axial Yeti XL | 7 | 02-24-2015 11:11 PM |
Transmission Only Bearing rebuild kits for Axial Yeti FastEddy Bearings | FastEddy | Axial Yeti | 0 | 10-30-2014 08:57 AM |
Team FastEddy/ FastEddy Bearings On Vacation. | FastEddy | General Crawlers | 0 | 06-21-2012 08:40 AM |
