05-09-2016, 03:36 PM | #21 |
Pebble Pounder Join Date: Sep 2015 Location: Wa st. Olympic peninsula
| Re: Spider gears notchey/hard to turn
Next time you have your diff apart take the diff cup and put it on a glass table to check that the face is level and not warped, this reads like it might warped may have had over tightened screws or the sealing face of the cup is not level, I have had a few vehicles in the past that were real sensitive to over tightening the ring or spur gear to the diff cup, best suggestion for anyone assembling diffs is to dry fit first. I know some guys will lay a piece of sandpaper on a glass table and give the sealing face of the cup a light sanding to make sure it is flat specially with plastic and all its imperfections, but in this case maybe removing material might not be the best idea. Also under neath the two spider gears top bottom check and make sure that their is not two AX31233 washers stuck together, that has happened to me before and it makes a difference, sometimes the two can get stuck together when shipped and they just magically stay stuck together. Also when filling diffs the general rule is to fill just over the cross pins leaving enuff room for the top spider gear, their is no need to fill it up level with the top of the diff, unless you like wasting oil :/ Last edited by jump_it; 05-09-2016 at 03:40 PM. |
05-09-2016, 04:22 PM | #22 | |||
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Spider gears notchey/hard to turn Quote:
05-09-2016, 04:26 PM | #23 | |
Quarry Creeper Join Date: Mar 2015 Location: florida
Now your just steering up turd first you responded by saying I should try my method first before suggesting. Now your bringing up my short comings from another rig, and accusing me of being a master shimmer ??? REALLY ???? do you even read posts your responding to and your responses before you even submit a reply. First off my YXL RTR weighs 15 lbs with electronics and 2 x 2s batteries, same as the 4 wheels and tires of the YXL MT project lemme repeat that YXL MT build 15 lbs just the wheels and tires, and since I'm using the same parts your assuming I'm applying the same methods to both .... REALLY???? . Right now I'm trying to decide if your trying to be funny or you just can't grasp what I posted and as I said it worked for my RTR I never made any guarantees it would work on their or that it would work on anything else. And besides I thought this is a forum of exchanging ideas to see what might work or won't work for you not the shoot down any idea that doesn't work for you because if it doesn't work for you it won't work for anyone else. My apologies to the OP and the rest of you reading this rant, ironic ??? because I hate drama, also to the moderators and if the mods feel this going to far please feel free to delete this post. | |
05-09-2016, 04:35 PM | #24 | |
on my stock cup from bottom to top, height wise I have 25.15 mm give or take. | |
05-09-2016, 05:47 PM | #25 |
Rock Stacker Join Date: Mar 2016 Location: usa
| Re: Spider gears notchey/hard to turn |
05-11-2016, 01:25 AM | #26 |
Quick update, ordered HR diff cup, new o-rings, and new washers. Already have HD gears, dhawk aluminum front bulkhead and fast eddy ceramics bearings. Hopefully I can get the notchey feeling figured out and have a solid front end. We'll see. Lol.
05-11-2016, 04:40 AM | #27 |
Pebble Pounder Join Date: Apr 2015 Location: New Jersey
| Re: Spider gears notchey/hard to turn The notchy diff should go away once you install the aluminum cup. I was having the same exact problem and was driving me crazy. The diff being notchy when taking apart a few times I can only think it's from some kind of warping. When i installed the aluminum diff cups the screws had a nice positive stop and no notchiness.
05-11-2016, 05:41 AM | #28 | |
THANK GOD! Glad I'm not the only one. | |
05-11-2016, 09:02 AM | #29 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
Looks like im not done spending yet lol
05-11-2016, 09:27 AM | #30 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
Dionisi, are you using the HR cup? I can probably swing by a LHS here in town and get the HR cup today. I would rather have the GPM diff cup, but that'll take at least a week to get here. I guess I could use one in the front and one in the trunk |
05-11-2016, 11:05 AM | #31 |
| Re: Spider gears notchey/hard to turn Yes I am using the hr cups, it's what was available at my shop(impulse buyer). Yea with hr I have really mixed feelings about them. Some machining I've gotten has been not the greatest in some of their products for example their piggybacks on the inside of the cap I noticed some flashing as if the milling was rushed or something.But some of the stuff they make is good not only in design but as in they are the only ones who pump out so many things.Also their 17mm hub conversion has been real good and I think they also widen the width a bit.
05-11-2016, 11:37 AM | #32 |
Newbie Join Date: Mar 2016 Location: Hustisford, WI
Did the double gasket not work?
05-11-2016, 12:51 PM | #33 | |
Do you have the 17mm hub conversion? I was thinking about picking it up to widen the stance, but since I need new tires and rims anyway I'm going to copy Pro Mod Steve. The Desperado wheels have a decent offset and don't seem to be made from licorice. | |
05-11-2016, 01:18 PM | #34 | |
05-11-2016, 04:16 PM | #35 | |
| Re: Spider gears notchey/hard to turn Haven't tried it, just said eff it and going with aluminum diff cup instead. Quote:
05-23-2016, 02:30 PM | #36 |
HR aluminum diff cup totally cured the notchey spider gears. Definitely worth it if your having the same issue.
05-23-2016, 02:35 PM | #37 |
Is there any way you could compare/measure the depth to the stock one ?
Spider gears notchey/hard to turn - Similar Threads | ||||
Spider gears | AngelowDoom | Axial AX10 2nd-gen | 1 | 09-04-2015 10:08 PM |
Wasted spider gears... | Twiztid Metal | Venom Creeper | 5 | 05-25-2010 11:16 PM |
stripped spider gears | AkFordfan | Tamiya CR-01 | 18 | 03-30-2010 11:56 AM |
MMMMMMM... Spider gears any one? | madmax22 | Venom Creeper | 13 | 01-27-2010 07:36 PM |
spider gears | crf250x | Venom Creeper | 9 | 01-14-2010 06:33 AM |
