06-12-2016, 11:56 AM | #1 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Shimming Diff Tight or Loose?
While I was assembling my rear axle I noticed the diff itself had a bit of side to side play within the housing and I decided to add a 0.2mm shim between the ring gear and the bearing to take this out. Now the diff is a bit tight (rotates smoothly but I can feel a bit of notchiness). There is 0 play between the pinion and ring gear. I have read up on shimming diffs (mostly 1/8 buggy stuff) and some people say to shim them tight and let them wear in while others say to leave a bit of backlash. I am thinking of removing 1 of the 2 shims behind the pinion gear to give it a bit more slack. I know the XL has had quite a few issues with stripping diffs and I want to make sure I get this right to do all I can to avoid the problem.
06-12-2016, 12:24 PM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Shimming Diff Tight or Loose?
Consider that all that gears can get worm and will dilate. So I don't think 0 play is an option. I like to setup mine as tight as possible without being notchy. And I'm sure the problem with Yeti's diff is not the pinion/gear but the bearings. Did anybody saw a destroyed diff with intact bearings?? I'm on my first set of diffs and I've had absolutely zero problem until now. Except a few teeth, both on front and back, exactly when the bearings gave up. ALWAYS the outer one, never the inner. Happily I was able to stop the car in time to save the diffs. Sent from my Sony Xperia Z5 Last edited by Tzicul; 06-12-2016 at 12:27 PM. |
06-12-2016, 12:36 PM | #3 | |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Shimming Diff Tight or Loose? Quote:
06-12-2016, 12:46 PM | #4 |
Yes and yes. And I have no idea what to do as a protection. It has to be corrugated and flexible and tough enough to resist down there
06-12-2016, 12:55 PM | #5 |
Heat shrink that is only heated on one end , with shoe glue or a small wire twist to secure it in place on the driveshaft.. OR PRO MOD Steve's style boot !! That looks like the best kind of material !! Anything will be a HUGE help !!! That thing is like a cement mixer getting dragged across the ground lol |
06-12-2016, 12:59 PM | #6 |
I already tried the heat shrink and I didn't liked it, it wasn't corrugated enough. What are you talking about Steve's mod????? Never saw it!!
06-12-2016, 01:04 PM | #7 | |
06-12-2016, 01:07 PM | #8 |
Oh, yes, I remember now. However I don't like it very much because it is not seal around the rear axle. Anyway, better than nothing. I suppose I'll do it also until something better comes to my mind. And it will! |
06-12-2016, 01:37 PM | #9 |
Deflecting is the main object.. Simplicity is a + as well.. I've been meaning to get onto this but been sidetracked by life lol im interested in your mod !
06-12-2016, 01:55 PM | #10 |
| Re: Shimming Diff Tight or Loose? |
06-12-2016, 01:57 PM | #11 |
Did Axial update the diff gears on this thing? The only ones I can find online are silver helical gears where as mine are black straight cut gears..
06-12-2016, 02:41 PM | #12 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
GPM also has upgrade set now, which should work ok. Maybe harborbash men can tell as GPM reseller?
06-12-2016, 02:59 PM | #13 |
| Re: Shimming Diff Tight or Loose? I have raised this want/demand to GPM .. the #45 steel straight beveled cut gears is all they offer at the moment ... but mid summer expect to see a variety of upgrades |
06-12-2016, 03:03 PM | #14 | |
but if you plan on running it once a month ... it will last 4-5 months without the HD Pinion mod After the mod they are the Toughest Gears on the market !!! Hands down !!! | |
Shimming Diff Tight or Loose? - Similar Threads | ||||
Shimming diff and the bulkhead | twisted | Axial Yeti | 5 | 06-30-2015 01:37 PM |
Diff shimming help | Dionisi | Axial Yeti XL | 3 | 04-28-2015 07:43 AM |
Shimming the diff gears | 95yjsahara | Axial Yeti | 11 | 03-29-2015 06:17 PM |
AX10 - diff shimming? | stewbaru | Axial AX-10 Scorpion | 1 | 12-19-2010 07:46 AM |
Diff shimming? | MOTORRAD | Traxxas Crawlers | 7 | 11-08-2004 09:47 AM |
