07-21-2016, 01:05 PM | #1 |
Newbie Join Date: Apr 2016 Location: Cumberland USA
| GPM steering bellcrank WAY under-sprung?
Hi all Originally I bought the HR steering bellcrank and found it to be quite nice except for the fact that it seemed to be binding right out of the package. The servo saver part of the HR bellcrank need some sanding/smoothing to operate well, so I just went back to the stock bellcrank with a gpm aluminum "steering mount". The stock bellcrank+GPM "steering mount" is actually pretty decent although it is a little under-sprung and doesn't quite return to center everytime because of it. So I ordered the GPM steering assembly to try. I just got back from my 1st run with a GPM aluminum steering bellcrank installed and found it to be SIGNIFICANTLY worse than the stock unit. It is hilariously under-sprung and not effective at turning the tires at all. A couple of questions to you guys: It is just my unit or have you found the same thing? Any mods? Is the Dhawk steering assembly any different or better? |
07-21-2016, 01:10 PM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: GPM steering bellcrank WAY under-sprung?
You can add a shim under the spring to un- under-sprung Sent from my Sony Xperia Z5 |
07-21-2016, 01:17 PM | #3 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
I personally think it should have a adjustable collar ... But... I didn't notice any serious issue.. I have noticed the play up and down on the post and eliminated that with a shim.. I did shim the inside of the stock servo saver but didn't find a need to with the GPM.. Is your front clip installed properly ? They can be a pain in the ass with out the Basher bar lol Dose the S.S compress easily ? |
07-21-2016, 01:48 PM | #4 |
Rock Stacker Join Date: Feb 2015 Location: Netherlands
The Spring included in the gpm unit is way to soft, when you replace it with the heavier stock Spring you will notice a huge improvement from stock.
07-21-2016, 01:59 PM | #5 |
Wow, thanks for the quick replies everyone! Tzicul - Any suggestion on shim size? If youve done this which part # did you use? I should probably order some to tune the steering. BHB - Yeah I hear you about reassembly, it's awkward at best. There is no vertical play of the steering assembly and I'm positive its in there properly. I noticed the spring in the GPM steering assembly was compressing pretty easily when I installed it, but I didn't compare to the stock spring so I figured it would be fine. BOY WAS I WRONG. Sjonnie82 - Thanks, I was hoping someone had tried this! I wasn't sure the stock spring would fit in the GPM unit, but I will try this before buying the DHawk unit. Has any one noticed binding in the servo saver portion of their HR Steering assembly? Honestly this seems like the superior unit (mine has NO slop) but the binding makes me worry about stripping the gears in my $180 servo if I were to take a hit. I'm thinking of slightly sanding and greasing it. Last edited by daveflave1275; 07-21-2016 at 02:19 PM. |
07-21-2016, 03:55 PM | #6 |
I used a regular wide shim, not rc type. I believe it was a 8 or 10mm inside with about 2mm thick, but I had to ground it on the outside, because it was too wide Sent from my Sony Xperia Z5 |
07-21-2016, 05:15 PM | #7 |
I use dry graphite dust for lubrication.. its cheep and doesn't attract dust and rocks like grease ... Possibly try polishing it with a dremel .. or use hand polishing compound before sanding it unless you have 1500 or 2000 grit available. Or 600 wet sanding. I think it would be beneficial leaving the crisp edges because the defer pebbles .. Hopefully this helps Has any one noticed binding in the servo saver portion of their HR Steering assembly? Honestly this seems like the superior unit (mine has NO slop) but the binding makes me worry about stripping the gears in my $180 servo if I were to take a hit. I'm thinking of slightly sanding and greasing it.[/QUOTE] |
07-21-2016, 11:46 PM | #8 | |
| Re: GPM steering bellcrank WAY under-sprung? Quote:
07-22-2016, 12:23 AM | #9 | |
BTW Dhawk and GPM Have no affiliation with each other .. I was shocked to find that as well because that's the misconception.. Last edited by BarHarborBasher; 07-22-2016 at 12:28 AM. | |
07-22-2016, 02:46 PM | #10 |
I am not saying that they are connected, but Dhawk sells also "rebranded" gpm parts....
07-22-2016, 06:38 PM | #11 |
I think he's a private wholesaler for them and offers them through his services..
GPM steering bellcrank WAY under-sprung? - Similar Threads | ||||
Hot Racing Steering Bellcrank vs. GPM | dempy | Tamiya XC/CC01 | 15 | 03-07-2016 05:26 AM |
Dhawk Steering Bellcrank | Duramarks | Axial Yeti XL | 14 | 11-21-2015 02:17 PM |
steering bellcrank? | demonoid369 | General Scale Talk | 1 | 05-16-2011 10:21 AM |
