08-05-2016, 09:13 PM | #1 |
Newbie Join Date: Feb 2014 Location: Kansas City
| First time out with new XL (Damage)
Had my new fresh out of tbe box XL in the backyard yard and had fun for about a half hour. Anyway my neighbors and my yard are connected with a slight dip between the property line. I got some speed and hit the dip and my XL came maybe 2 feet off the ground and rolled three times. Our yards are all low cut grass and somehow I ended up with a broken lower rear link. So where do I get parts and is there an upgraded part I shoukd be looking for? If so who do I order from? |
08-05-2016, 09:16 PM | #2 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Re: First time out with new XL (Damage)
E-BAY or AMAIN hobbies. hot racing makes aluminum links
08-05-2016, 09:37 PM | #3 |
Thank you, I may look at the aluminum ones.
08-06-2016, 12:10 AM | #4 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
You can try also Towerhobbies
08-06-2016, 12:15 AM | #5 |
Thank you, I will check out Tower. Im just not sure what brand to buy. Im looking at Vanquish products but they are out of stock. Im looking at Hot Racing but the bad reviews Im reading has me leary.
08-06-2016, 12:36 AM | #6 |
You can go with GPM/Dhawk, the drive shaft, for example, is way better than HR's. For the bearings, I'm not sure if a $12 bearing from boca is twelfe time better than a $1 no name bearing. It's your choice as long as you change them before they fail Sent from my Sony Xperia Z5 Last edited by Tzicul; 08-06-2016 at 10:06 AM. |
08-06-2016, 12:48 AM | #7 |
Ok just ordered Dhawk upper and lower rear links and mounts. Wow already upgrading.
08-06-2016, 07:09 AM | #8 |
Newbie Join Date: Jul 2016 Location: hebron
I assume that you have the rtr? I also purchased a rtr (slightly used) and can tell you that there are some must do upgrades. I purchased HR'S front sway bar and rear torsion bar to help eliminate the twist making it more controlable. I also purchased a HR motor mount, one as a heat sink and two to stop any motor movement when you punch the throttle.
08-06-2016, 09:59 AM | #9 |
Yes I have the RTR, Im just suprised something broke that fast.
08-07-2016, 09:07 AM | #10 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
Don't be that is out of the box Axial for you. They make nice trucks but they all need upgrades out of the box is you want to keep running. Sucks but that is the way the hobby is really, no matter what brand you get. Sent from my iPhone using Tapatalk |
08-07-2016, 09:38 AM | #11 |
Thats cool, I have a few aluminum parts on order. Almost seems that I like working on it as much as using it.
08-10-2016, 11:14 AM | #12 |
Pebble Pounder Join Date: Jun 2016 Location: Keizer
Even with the kit version requires some upgrades. You should really look at the BHB HD gear mod if you want your diffs to hold up to bashing.
08-13-2016, 10:04 AM | #13 |
| Re: First time out with new XL (Damage) |
08-13-2016, 10:54 PM | #14 |
I got my pinions back from him today, they look great!
08-14-2016, 04:57 AM | #15 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
First time out with new XL (Damage) - Similar Threads | ||||
Acetone damage? | RubikonKid | Tires and Wheels | 20 | 12-25-2013 05:50 AM |
how much damage will be done? | freakofnature | Electronics | 5 | 06-20-2012 08:26 AM |
damage? | m3kan1k | Axial SCX-10 | 4 | 03-11-2009 01:40 PM |
More Damage | cwkoehler | General Crawlers | 1 | 03-23-2008 08:37 PM |
Course damage | Cloak | Competitions | 9 | 06-11-2007 11:50 AM |
