Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: RR slipper - Heads Up
Old 09-07-2016, 07:02 PM   #1
Default RR slipper - Heads Up
If you are going to install the RR slipper, the spacer that goes against the tranny needs to be cut down. The pocket is too deep and causes the spacer to bottom out on the plastic tranny case when tightened.
Pilot-Werx is offline   Reply With Quote
Old 09-07-2016, 07:10 PM   #2
Default Re: RR slipper - Heads Up
Did you bore out the transmission case first fir the collar? Just wondering
BarHarborBasher is offline   Reply With Quote
Old 09-07-2016, 07:59 PM   #3
I thought about it but I did not want to remove material where the bearing sits. The rear spacer is stepped to match the oval part of the shaft. The problem is that it was bottoming out on the plastic before bottoming out on the step in the spacer.
I also noticed that shaft will move in and out about 1 or 2mm without anything attached by pulling/pushing on it with your fingers. I tried putting a spacer inside but it just caused the shaft to bind. Have you noticed any movement in the shaft itself?
Old 09-07-2016, 08:29 PM   #4
there is a big thread on this from last year. you have to open up the case hole.
pro mod steve is offline   Reply With Quote
Old 09-07-2016, 08:58 PM   #5
Yes there is a thread all about this. The reason it doesn't fit is because its ment for a 10th scale yeti. You need to modify the tranny and bore the hole so the spacer sits against the bearing on the top shaft. Plenty of people including me have successfully made it work and haven't had any issues since boring it out.
84yoda is offline   Reply With Quote
Old 09-07-2016, 09:01 PM   #6
I will see how this works out and if needed open the case. Note to self, winding the stock one down will cause the plastic rear shaft to twist like a candy cane...
Old 09-07-2016, 10:33 PM   #7
Yeti XL Drive Shaft Mod ( As seen on the Wraith )
Read this
Old 09-08-2016, 06:33 PM   #8
I replaced it with an HR. The splines are literally twisted like a spiral preventing it from sliding. Stripped it down this morning and surprisingly everything is looking pretty good.
RR slipper - Heads Up - Similar Threads
Slipper Pads for Gen 3 Slipper? Markeje Axial Wraith 0 05-16-2014 09:13 AM
10T Holmes Puller and 3s : Slipper or no slipper? utieh General Crawlers 2 12-28-2011 07:42 AM
