10-16-2016, 05:51 PM | #1 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
| Stock rear driveshaft woes.
So I broke 3 HR rear shafts and 2 GMP shafts wich lasted 10 times longer than the HR. So I did the stock shaft mod with the bolt threaded down the hollow shaft. After about 15 6S runs it is starting to twist. Not bad yet but it's going south. Ordered another GMP as it served me well for a while. What is everyone else doing about the rear shaft? AGAIN I apologize for my earlier STUPID post. I feel so bad about that. |
10-16-2016, 05:56 PM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Stock rear driveshaft woes.
Still on my second GPM shaft. The first one was from the first generation, so it didn't counts. What post are you talking about??? Sent from my Sony Xperia Z5 |
10-16-2016, 07:39 PM | #3 |
I wonder if these 8mm MIP Hubs - Super Shafty would work with the goofy Pinion. Then you could run these MIP MAD SHAFTS - Super Shafty If it wasn't for the goofy pinion i would run the Kraken Vekta5 DS. KV2225 |
10-16-2016, 08:57 PM | #4 |
| Re: Stock rear driveshaft woes. |
10-16-2016, 10:25 PM | #5 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
this thread reminded me that I have to get something in the mail soon since my driveshaft is starting to do the twist..
10-16-2016, 10:35 PM | #6 |
10-16-2016, 11:59 PM | #7 |
| Re: Stock rear driveshaft woes. No mod, a while back I threaded a 5/16 setscrew into it but I couldn't fit the 2 pieces together. It wasn't till later that I realized I was supposed to tap the hole first. The plastic definitely stretched a little bit which has probably made it weaker but it has still held up for a few months, mind you I only drive 4s. I'm tempted to just buy a new stock shaft and mod it but I'm definitely looking at the gpm too.
10-17-2016, 03:52 AM | #8 |
Rock Stacker Join Date: Jul 2016 Location: Amsterdam
My stock shaft twisted (only slightly) after 3 runs. I did the epoxy mod, filling the shaft to the rim. It probably can handle some more runs, but am currently bolting on the GPM steels haft now, assuming it would never break. Bit worried that you managed to break it. What happens? Does it snap?
10-17-2016, 06:16 AM | #9 |
Both broke at the front pivot where it goes on the transmission. Thought I saw somewhere here there was a second design with a stronger pivot point to correct this problem .
10-17-2016, 06:23 AM | #10 |
Yes, it is. At my recommandation Depends when you purchased yours. They upgraded the shaft sometimes between february 17th and april 1st. You can check, if the original Axial pivot (or ball end) doesn't fit the GPM cup by one or two millimeters, than you have the first version. Sent from my Sony Xperia Z5 Last edited by Tzicul; 10-17-2016 at 06:30 AM. |
10-17-2016, 06:34 AM | #11 |
10-18-2016, 07:09 PM | #12 |
Rock Stacker Join Date: Feb 2016 Location: Kennebunkport
I went the HR route and have not looked back. Has been bulletproof.
Stock rear driveshaft woes. - Similar Threads | ||||
Rear driveshaft | rob4607 | Axial Yeti XL | 9 | 03-31-2015 12:24 PM |
Wraith driveshaft woes... | norco kid | Axial Wraith | 8 | 10-17-2012 11:32 PM |
driveshaft woes | sb4pro | Venom Creeper | 3 | 11-21-2009 11:14 PM |
Driveshaft woes... | scaryfast12 | General Crawlers | 23 | 11-16-2008 12:49 AM |
