Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: 6X6 or MAD POWER concept
Old 10-28-2016, 09:59 AM   #1
Default 6X6 or MAD POWER concept
6X6 Bulkhead .... This is a build down the line but it would be a COOL one !!
Ok this is barely related to the XL forum.... other than its using a XL bulkhead..
This is a concept for speedrunners.. I've been following them pretty close and this is what I came up with to push the boundaries a little more The Idea is a controllable Center Diff / viscosity or Rubber diff/spool in a protected enclosure with HD pinion gears with preset mesh that can take some serious abuse !! The outputs will be replaced with drive pulleys for ratio combinations. The Custom outputs will be Keyed into the sungear pocket for EXTRA strength ...
BarHarborBasher is offline   Reply With Quote
Old 10-28-2016, 05:37 PM   #2
Default Re: 6X6 or MAD POWER concept
Wholly ticking time bomb batman. Awesome idea but even packed full of Trojan rubbers turned inside out for the YXL diffs pleasure do I think that will last. I hope it does cause that's a way way out there concept.
cmbscx10 is offline   Reply With Quote
Old 10-28-2016, 06:52 PM   #3
It defiantly is a far out concept ... But... I think after I modified the sungears/lapped and providing outputs that provide 1000% more surface contact than the pin design.. Ive never had a issue with the plastic cup surprisingly enough
Now far as a XL Beast III 6X6 with a 2028...mean machine
Old 10-28-2016, 07:20 PM   #4
OK you just confirmed it. YOU are nuts!!! (just kidding)? So when you come up with these ideas does your brain start smoking. You are way outside of my realm of rc. I do good keeping my stuff running and you go and reinvent the wheel.
pro mod steve is offline   Reply With Quote
6X6 or MAD POWER concept - Similar Threads
mad force 6x6 w/dewalt motor mrluckies Kyosho Crawlers 4 02-03-2015 04:58 PM
mad force 6x6 spyderwebbcustoms Kyosho Crawlers 15 02-26-2012 04:43 PM
6x6 Lacking power rcmaniac24 Electronics 8 05-03-2010 07:42 PM
