11-26-2016, 03:41 PM | #1 |
Rock Stacker Join Date: Oct 2016 Location: Detroit Lakes
| Electronics Connector Help
Here are the items I am purchasing for the yeti XL.Since I'm new to electric, what all do I need to hook this bad boy up? Also is that servo horn ok to use Sent from my iPad using Tapatalk Pro |
11-26-2016, 04:36 PM | #2 |
| Re: Electronics Connector Help
Also I will be running on 6s ....any help here on what connectors and things I need to hook this all up....first electric
11-26-2016, 04:55 PM | #3 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
TRAXXAS #5626 will mount the esc. You need a Castle EBEC and extra some wire or cable to tie the 2 esc connectors together. I got a piece of Castle wire same size as esc off ebay for cheap.
11-26-2016, 04:56 PM | #4 |
Rock Stacker Join Date: Oct 2016 Location: Staten Island
I use traxxas connectors for the esc to battery part # 3070
11-26-2016, 05:00 PM | #5 |
| Re: Electronics Connector Help |
11-26-2016, 05:02 PM | #6 |
I run the same set up in both my YXL. Turn the punch and brake control down with the Castle Link for 6S. https://www.amainhobbies.com/castle-...079-00/p177606 Use this and you can hook up Castle Link with out going into the receiver box to make changes. Last edited by pro mod steve; 11-26-2016 at 05:05 PM. |
11-26-2016, 05:07 PM | #7 |
Most important take your time and plan ahead. Time spent here will make the difference between hack and afterthoughts and nice and neat. One thing I did but it was a pain is I bought new connectors for everything going to the receiver so I could get the wires as short as possible. Some are long and there is not much room in the receiver box especially with an ebec and y-harness. Last edited by pro mod steve; 11-26-2016 at 05:14 PM. |
11-26-2016, 05:13 PM | #8 |
Thanks pro mod Steve....much help...I'm sure I will have a lot more lol Sent from my iPad using Tapatalk Pro |
11-26-2016, 05:23 PM | #9 |
That's what I am here for.
11-26-2016, 05:30 PM | #10 |
I'm getting all of my stuff through horizon....can you show me which bec I should get from there? Sent from my iPad using Tapatalk Pro |
11-26-2016, 05:38 PM | #11 |
The small blue Castle ebec. Think its 10 amp. Might take a look at AMain I get a lot there good place fast shipping.
11-26-2016, 05:56 PM | #12 |
Is this the one Sent from my iPad using Tapatalk Pro |
11-26-2016, 11:02 PM | #13 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Yes. Pick up or make your own rx bypass harness. Holmes sells them or you can also make one from a Y harness.
11-26-2016, 11:23 PM | #14 |
Rock Stacker Join Date: Mar 2016 Location: Los Angeles
I think the servo comes with a metal servo horn. At least that's what I got in my 7950TH for my scx. Sent from my iPad using Tapatalk |
11-26-2016, 11:24 PM | #15 |
Why not the 7950TH? Just wondering. Extreme power just about $20 more. Or the spektrum high torque one Sent from my iPad using Tapatalk |
11-27-2016, 12:10 AM | #16 |
Pebble Pounder Join Date: Apr 2016 Location: Australia
I'm running same combo except for servo and Bec. Get a better servo if you can. Makes a huge difference.
11-27-2016, 10:13 AM | #17 |
Which y harness are you talking about can you send me a picture or link...very first electric here ....tia Sent from my iPad using Tapatalk Pro |
11-27-2016, 11:16 AM | #18 | |
| Re: Electronics Connector Help Quote:
Holmes Hobbies and Gear Head RC have them. I prefer the Gear Head one, less wiring. I think cheaper too. http://www.rpphobby.com/product_p/gea1346.htm Sent from my iPad using Tapatalk | |
12-01-2016, 07:49 PM | #19 |
Ok so wiring up my yxl tonight, I am running cc bec 10amp ran it to my rx, hooked up esc to rx pulled red wire out, but now question I have is, I also have the castle link quick connect that gets hooked to the esc right? Should I put red wire back into the esc? So Before I plug quick connect to rx pull red wire from the quick connect? Sent from my iPad using Tapatalk Pro |
12-01-2016, 08:22 PM | #20 |
| Re: Electronics Connector Help http://i646.photobucket.com/albums/u...64606335_n.jpg this. its the servo NOT esc You are powering the servo through the EBEC instead of just the esc. Last edited by pro mod steve; 12-01-2016 at 08:24 PM. |
Electronics Connector Help - Similar Threads | ||||
Tamiya connector G2.5 | mactech | Electronics | 13 | 07-04-2012 03:04 PM |
looking for a Y connector | jon1197 | Newbie General | 5 | 12-17-2009 08:35 AM |
Which Connector | Dutchy | Electronics | 17 | 10-06-2009 08:45 PM |
what's the name of this connector? | muddeprived | Electronics | 16 | 06-04-2009 12:15 PM |
