01-17-2017, 06:55 PM | #21 |
Rock Stacker Join Date: Jan 2014 Location: Belleville, Ontario, Canada
| Re: RC4WD Rear Housing |
01-22-2017, 12:57 AM | #22 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
01-25-2017, 10:29 AM | #23 |
Yes it was ... Thank-you. I think that is one of the best mods I have seen, little effort or cash but great results.
01-26-2017, 10:14 PM | #24 |
Pebble Pounder Join Date: Feb 2016 Location: Stillwater
Has anyone ran the axle with non-modded gears to see if it binds? I love the BHB mod as it fixed a huge issue but id love to have an axle that would mean I don't have to worry about modding a new set should the ones I have ever fail! Sent from my iPhone using Tapatalk |
01-27-2017, 06:25 AM | #25 |
Not here. My BHB gears have been perfect so I haven't needed to replace any for a long time.
02-14-2017, 07:26 PM | #26 |
Pebble Pounder Join Date: Sep 2015 Location: Wa st. Olympic peninsula
I just installed the stock gears on my RC4WD axle, they fit, no play with 2 shims and dhawk aluminum spacer... will not know if they work till I run it, when ever that happens.... it's on the super slow build list.
02-14-2017, 08:13 PM | #27 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: RC4WD Rear Housing You must be using the Straight cut gears ? I wonder how the HD gears fit/opperated ?
02-14-2017, 09:46 PM | #28 |
Pebble Pounder Join Date: Feb 2017 Location: SoCal
Good question. I got the HD gears with my kit but I don't have the RC4WD axle.
02-15-2017, 08:28 AM | #29 |
I notified RC4WD about " IF " there's a problem a serface shim/meatering plate could be installed in-between the third member and the housing surface. I'm curious to hear a verdict.
02-15-2017, 05:02 PM | #30 | |
| Re: RC4WD Rear Housing Quote:
I did not like the black, but will say they did a good job powder coating the axle, dunked mine in greased lightning over nite and still have spots to remove, if you dunk yours I would suggest not doing the half the has the pinion as the inside is powder coated to the specs of bearing fitment, removing that material could leave it a little sloppy in their Ive been removing the paint on outside of that part by hand | |
03-16-2017, 02:27 PM | #31 | |
I reached out to RC4WD about their axle housing and the HD gears. Here was their response: Quote:
03-17-2017, 04:13 AM | #32 | |
I contacted them multiple ways explaining the HD debacle letting them know if they made a shim that when in between the housing in the third member it would allow the proper mesh but it seems like I light my self on fire for a manufactors to listen to me so far Dhawk is the Only company that resolves issues... Goodluck with your endeavors... | |
03-17-2017, 09:57 AM | #33 |
Pebble Pounder Join Date: Apr 2015 Location: New Jersey
Yea unfortunately vanquish won't make a revised rear for the xl. I wonder why. Is it his love for crawlers? Or just thinks he won't sell many maybe. All I know is it was a nice peice. Ud think MIP would also be all over this thing like stink on shit but nooo. If it wasn't for hotracing or dhawk their wouldn't be much for it.
03-17-2017, 10:46 AM | #34 |
I'm not sure that there even is a problem with the RC4WD housing yet. The HD gears meshed just fine in my original axial housing with no shimming, and if the RC4WD one is similar enough, they might work fine with it too. We will see. Like I said, I'll update when I hear something back.
03-17-2017, 11:02 AM | #35 | |
They'll be perfect then .... Pete from socal...Are you a insider lol | |
03-31-2017, 12:22 AM | #36 |
I'm not sure what you mean BHB? I'm not trying to pick any kind of fight here. I heard back from RC4WD. They said their warehouse tried the HD gear set and it fit well. When my budget allows (sooner rather than later) I'll pick up the axle housing and try the unmodded HD gears, see how they do. |
04-27-2017, 05:16 PM | #37 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Any feedback on the axle steve? Sent from my SM-N920V using Tapatalk |
04-27-2017, 08:53 PM | #38 |
Except for the ton of small screws that hold the pinion assembly to the main housing it is bullet proof. I like it.
04-28-2017, 10:33 AM | #39 | |
This is a last, one time effort to resurrect this beast that has been collecting dust for the last 6 months. I love driving it, but it has been a money pit. | |
04-28-2017, 10:34 AM | #40 |
RC4WD Rear Housing - Similar Threads | ||||
Anyone not like the VP rear housing (non-currie) on yeti - and why? | baggg | Axial Yeti | 6 | 07-20-2016 03:28 AM |
Anyone not like the VP rear housing (non-currie) on wraith - and why? | baggg | Axial Yeti | 0 | 07-15-2016 08:37 PM |
Vanquish rear diff housing | pro mod steve | Axial Yeti XL | 7 | 11-28-2015 12:25 PM |
Need a rear axle housing pic. | run2jeepn | General Crawlers | 0 | 12-25-2005 02:54 AM |
