Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti XL
Thread: RC4WD Rear Housing
Old 12-03-2016, 05:18 PM   #1
Default RC4WD Rear Housing
Went together perfect no issues at all. Gears are super smooth. Only problem is the screw for the top arm mount from the stock housing will not work as it is countersunk and the RC4WD mount is flat. Axial screw #AXA0094 works perfect. It absolutely adds some weight to the rear. Really not to thrilled with the small screws that hold the pinion housing to the main housing but there are a lot of em.
pro mod steve is offline   Reply With Quote
Old 12-03-2016, 05:22 PM   #2
Default Re: RC4WD Rear Housing
Old 12-03-2016, 06:15 PM   #3
Is it updated in anyway to accept the HD pinion without the mod?
Shiesty2000 is offline   Reply With Quote
Old 12-03-2016, 06:17 PM   #4
This looks great, really promising. I assume the BHB mod isn't required? And do you know the weight difference?
SvdV is offline   Reply With Quote
Old 12-03-2016, 06:28 PM   #5
Don't know the pinion I used already has the BHB mod.
Old 12-04-2016, 07:16 AM   #6
Looks great, but why do parts like this in black? They look terrible once the rock rash settles in......
Curb Crawler is offline   Reply With Quote
Old 12-05-2016, 09:54 AM   #7
Oohh ya sweet I can't wait to get one of my own I will be able to run my yeti on full power again and not on 3s turned way down hopefully I'll get it ready in time for the long run in Johnson valley I was just planning on driving the chase rig this year
ferp420 is offline   Reply With Quote
Old 12-05-2016, 11:33 AM   #8
ordered mine yesterday
rcbasser is offline   Reply With Quote
Old 12-05-2016, 06:30 PM   #9
Originally Posted by pro mod steve View Post
How much was that Steve?
Skyman is offline   Reply With Quote
Old 12-05-2016, 09:11 PM   #10
$150 . . . is it this one? --> LINK
Axial Rose is offline   Reply With Quote
Old 12-05-2016, 09:13 PM   #11
Yep
Old 12-06-2016, 01:44 AM   #12
I'm going to order one in the new year
Old 12-07-2016, 02:27 PM   #13
Looks great Steve !! I'm sure a higher grade fastener can be found or possibly a hardened pin ?
I'm interested if it's going to bind up with the HD gears like the Vanquish does without the mod...
Some food for thought....If a gasket (spacer) was installed between the housing and third member it would pull the pinion away from the ring gear allowing the (stock Axial HD gear to be used) ...
Sort of like the option that I through at Harley. Adjustable pinion member..
Too bad companies don't read this shit lol
BarHarborBasher is offline   Reply With Quote
Old 12-07-2016, 06:06 PM   #14
Good idea, in the turbo world when you crank your boost up you can lower compression by increasing head gasket thickness. I image it would be fairly easy to create a shim for this axle. Maybe rc4wd would consider making a shim for it depending on what gears they designed it around
Lavaheadache is offline   Reply With Quote
Old 12-08-2016, 12:11 AM   #15
Originally Posted by Lavaheadache View Post
Good idea, in the turbo world when you crank your boost up you can lower can compression by increasing head gasket thickness. I image it would be fairly easy to create a shim for this axle. Maybe rc4wd would consider making a shin for it depending on what gears they designed it around
Oho I know about that old trick... in the opposite manner... thinner or no gasket at all for higher compression in naturally aspirated engines lol I'm sure pro mod Steve could probably teach us a thing or two!
But yes that's exactly the concept that I was conveying. Adjustable pinion mesh shims ..
Old 01-14-2017, 05:32 PM   #16
Well after a lot of rain finally got out today to put a basing on this thing. I really like it. Ran 3 6S packs today and not 1 issue. The weight seems to help that too light in the rear issue as far as bouncing off the ground from a jump.
Old 01-17-2017, 03:35 AM   #17
Any videos Steve? I think the stock one looks cooler, but I haven't driven mines yet. It's still incomplete. Seems like I've spent more time upgrading parts, before I even put in electronics.
Mudman is offline   Reply With Quote
Old 01-17-2017, 07:11 AM   #18
Sorry I don't do videos.
Old 01-17-2017, 07:02 PM   #19
Hey Steve: I have a tip for holding the cage in the up position. Use a longer screw with a rubber bushing, in the rear screw hole for the upper link mount on top of the pumpkin. Works great and does not seem to get in the way of anything else[ATTACH]Name:  IMG_0369.jpg
Size:  86.4 KB[/ATTACH]
Old 01-17-2017, 07:38 PM   #20
Originally Posted by rcbasser View Post
Hey Steve: I have a tip for holding the cage in the up position. Use a longer screw with a rubber bushing, in the rear screw hole for the upper link mount on top of the pumpkin. Works great and does not seem to get in the way of anything else[ATTACH]Attachment 354141[/ATTACH]
That pinion cap is gonna save up headaches as well I did the same mod to my vanquish
RC4WD Rear Housing - Similar Threads
Anyone not like the VP rear housing (non-currie) on yeti - and why? baggg Axial Yeti 6 07-20-2016 04:28 AM
Anyone not like the VP rear housing (non-currie) on wraith - and why? baggg Axial Yeti 0 07-15-2016 09:37 PM
Vanquish rear diff housing pro mod steve Axial Yeti XL 7 11-28-2015 01:25 PM
Need a rear axle housing pic. run2jeepn General Crawlers 0 12-25-2005 03:54 AM
