02-23-2017, 03:25 PM | #1 |
Newbie Join Date: Feb 2017 Location: Wilmington
| Guess its time for some new wheels...(take 2)
Lets see if the pics worked this time... Looks like on my second trip out I managed to strip the back of the wheel where it attaches to the axle. It seems like this is a common problem so what is a good solution? Hot Racing make some good parts for this? Hopefully the pictures came through so you can see what I am working with. Got the XL off eBay and it was the kit version so I think it is totally stock? What about some good wheels? I searched on here and it seems like all the ones I like are either not sold anymore or I have to modify them. |
02-23-2017, 04:30 PM | #2 |
Newbie Join Date: Feb 2017 Location: sw bristol....uk
| Re: Guess its time for some new wheels...(take 2)
I see a good few going with the stock tyres on proline 3.8 rims......good strong rims and not gonna brake the bank....unless u have £$200+ to chuck at sum......and sum ci closed cell foams r very good......I stripped off my stock kit rims/tyres today in the oven....
02-23-2017, 06:10 PM | #3 |
Do you know what the part number on the Proline wheels is? I will check them out...
02-23-2017, 06:54 PM | #4 |
Rock Crawler Join Date: Dec 2014 Location: friendswood, TX
It is the Pro Line 3.8 1/2 offset either the desperado or F-11. I started with the desparados and they warped pretty bad after a few months. I am now using the F-11 but still to new to give any data BUT either one is way better than stock. I went through the stripped wheel spiral way back when I first built my kit. I spent soo much on wheels and tires it makes me sick. To the fix to your problem. it is NOT the stock wheel nuts it is the power applied. Turn down the punch control and turn down the brake. Get the truck rolling before you turn on the power. You have to be smooth on the throttle or it will keep eating wheels. I did not follow these rules at first and would go through wheels like they were free and they ain't. Since I changed my driving style I haven't had a wheel hex failure in over a year. yes you can still go nuts and wide open and have fun. just get that mass of weight moving first. Good luck.
02-23-2017, 06:57 PM | #5 |
| Re: Guess its time for some new wheels...(take 2) |
02-23-2017, 07:39 PM | #6 |
Hey Steve...I think I have read almost every thread on wheels here and am about to go blind. I think I have (had) the MT4 but maybe I will give the F11's a try since they are pretty inexpensive. Will my stock BFG tires fit on them or do I have to modify since they are a Traxxas bead? I will get some of the foam inserts you used also. I am actually very easy on the gas and brakes but I got this monster from eBay so no telling what the guy before me did to it! Will those F11 wheels also work with this..."17mm Hub +8mm Hub W Serrated Nuts - Yeti Xl Kit"? I should buy that yes? Sorry for all the questions! |
02-23-2017, 10:41 PM | #7 |
Pebble Pounder Join Date: Apr 2016 Location: Australia
Blue locktight is all you really need. I half stripped one of my rims like on the 2nd run (check my thread), I did put the hr Hubs on the rear after but my fronts are still stock and are fine. It's mainly just your wheel nut coming loose then stripping your rim. Sent from my iPhone using Tapatalk |
02-24-2017, 12:52 AM | #8 |
Quarry Creeper Join Date: Apr 2016 Location: Cape cod
My XL kit will be 1 in a couple of months and I'm still kicking with the original wheels with a 2200 MMX combo on 4s and tons of heavy aluminum upgrades. I run zero punch control and hammer the throttle all the time even on pavement. It is meticulously maintained and has been basically trouble free for a long time.
02-24-2017, 05:49 AM | #9 |
Pebble Pounder Join Date: May 2016 Location: France
I had F11 on my savage flux for a while running 6S 2000kv, the hexs were tough as hell !
02-24-2017, 07:21 AM | #10 |
Rock Stacker Join Date: Feb 2015 Location: Northern Illinois
The only time I have stripped a wheel is when it worked it's way loose. To stop this I use teflon tape over the threads. I've had no problems since.
02-24-2017, 08:15 AM | #11 |
Hey guess thanks for the info! It helps a bunch. I just put in an order for... - Proline F11 wheels - HR 17mm hub kit - CI foam inserts - assorted screws/nuts and body clips (always losing them) I will get some pictures up when I get it together In the meantime, I cut out a small round patch from my mountain bike tire tube, cut out a hole in the middle, put it over the axle and nut, then just put the stripped wheel over that and tightened it. The rubber actually helps the plastic "bite" and I now have four wheel drive again until my new wheels come in!! |
02-24-2017, 08:25 AM | #12 | |
Pebble Pounder Join Date: Sep 2015 Location: Wa st. Olympic peninsula
| Re: Guess its time for some new wheels...(take 2) Quote:
Guess its time for some new wheels...(take 2) - Similar Threads | ||||
well time for a new build i guess | hotrodsonoma | 1.5 Scale Rigs | 14 | 12-02-2011 02:41 PM |
Time for New Wheels | mgauger | Axial XR10 | 18 | 05-10-2011 03:23 PM |
well i guess its time i build a 1.9 comp tuber | rockbound | Losi Mini-Rock Crawler | 58 | 02-14-2010 08:51 PM |
Wheels.....time to get serious | Deezul | Tires and Wheels | 25 | 03-20-2009 10:51 PM |
