03-22-2017, 04:57 PM | #1 |
Newbie Join Date: Aug 2016 Location: New Zealand
| Straight cut gears v Sprial cut gears
Hi all Decided it was time to pull the diffs out of the XL. My diff gears are straight cut . The rear gears are still in good condition ( using the 3 bearing mod ) but the front diff gears are starting to show a small amount of wear( haven't done the 3 bearing mod yet ) My question is should I replace the gears with the spiral ones, whats the advantage over the straight cut gears. Also deciding on what oil should I put in the front and rear diffs ? Thanks guys |
03-23-2017, 02:41 AM | #2 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
| Re: Straight cut gears v Sprial cut gears
Main problem with the diffs is not the pinion itself, but the bearings. My first set was a straight cut which failed only when the bearings failed. So do the three bearing mod in front also and keep your original pinion/ring until they'll need replacement. It will take some time! Sent from my Sony Xperia Z5 |
03-23-2017, 12:55 PM | #3 | |
| Re: Straight cut gears v Sprial cut gears Quote:
Cheers | |
03-23-2017, 11:53 PM | #4 |
RCC Addict Join Date: Jan 2016 Location: Bar Harbor
| Re: Straight cut gears v Sprial cut gears I ran ithe WAX mod for 4 months and it's awesome! I ended up doing my Banshee XL and Bomber XL front diff with WAX.
03-24-2017, 06:59 AM | #5 |
Newbie Join Date: May 2016 Location: The hills
My mate and I have been running straight cut for a year and no problems. Once we replaced the bearings with decent bearings we have had no problem. I run ali front bulkhead and ali diff cup and get no gear slipping, my mate has plastic ones and gets some slipping of the teeth occasionally.
03-24-2017, 10:20 AM | #6 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Straight cut gears v Sprial cut gears |
03-24-2017, 05:32 PM | #7 |
| Re: Straight cut gears v Sprial cut gears Melts down in a few seconds bashing probably comparative to 100,000 cst. ... If I start off crawlings it pretty much stays locked .. the best part is it hardens back up so Everytime the choice is mine. I've noticed that silly putty has a reaction to the powdered metal. The wax is 100% safe.
03-27-2017, 08:36 PM | #8 |
Just out of curiosity does anyone know if any other straight gears ie the same pitch and number of teeth or complete diff will fit into the xl housing |
04-19-2017, 05:25 PM | #9 |
Pebble Pounder Join Date: Apr 2017 Location: Fresno
I was just looking at this when I realized I needed to replace my gears after a bearing failure. I'll ok into the 3 bearing mod too. Thanks for posting about this! |
Straight cut gears v Sprial cut gears - Similar Threads | ||||
only cut tires. post up your cut tire photos | evan03 | Tires and Wheels | 172 | 12-05-2021 07:54 PM |
Dove cut, bobbed, cut, chopped, you name it its been threw it... California Raisin... | Madjones | Losi Micro-Rock Crawler | 6 | 11-17-2014 09:07 AM |
bevel cut vs straight cut?????? | savagebeast | Axial Wraith | 10 | 12-19-2012 12:18 PM |
bevel cut vs straight cut?????? | savagebeast | 2.2 Scale Rigs | 2 | 12-18-2012 05:49 PM |
