12-18-2012, 03:23 PM | #1 |
Quarry Creeper Join Date: Jun 2008 Location: LaPorte
| bevel cut vs straight cut??????
I just destroyed a set of bevel cut hi speed hd axial pin and ring gears. I ordered a new set of the bevel cut stock gearing HD gears. I am running a pro 4 / mmp and was wondering if anyone had info on the set that would last longer with the setup i have. should I use the straight cut or bevel cut gears??
12-18-2012, 03:26 PM | #2 |
| Re: bevel cut vs straight cut??????
Maybe your bearings are bad or it needed to be shimmed? The bevel gears should hold up for a while... I have also ruined a set but it was user error. |
12-18-2012, 04:54 PM | #3 |
Right on, I had no shims at all, how would u know if it's Shimmed right? Sent from my SGH-T889 using Tapatalk 2 |
12-18-2012, 04:56 PM | #4 |
If it has a lot of play in he pinion gear, sliding forward and back, you need shims.
12-18-2012, 08:11 PM | #5 |
The plastic axle housing can be warped when you have the gears fail. You should carefully look at the axle to make sure it isn't warped or binding so you don't wreck the new gears. If you aren't sure replace the axle housing because it is cheaper than gears. |
12-18-2012, 08:29 PM | #6 |
If you blew up a set of gears then your housings are shot. Once you blow gears and its not bearing related then you need to replace the housings. You can just get new plastic versions or upgrade to aluminum. I had stock gears for almost two years one a Pro4 in aluminum housings. |
12-18-2012, 11:19 PM | #7 |
I am running full vp everything, axles and all. I'll check the bearings, it did have play as lt wasnt shimmd. Sent from my SGH-T889 using Tapatalk 2 |
12-19-2012, 07:31 AM | #8 |
| Re: bevel cut vs straight cut?????? I would check your pinion bearings first of all. I have replaced mine with bronze bushings to fix that problem. The Pro4 loves to eat up those bearings.
12-19-2012, 11:50 AM | #9 |
Really, where did u order them? Thanks Sent from my SGH-T889 using Tapatalk 2 |
12-19-2012, 11:52 AM | #10 |
| Re: bevel cut vs straight cut?????? |
12-19-2012, 12:18 PM | #11 |
Quarry Creeper Join Date: Jul 2012 Location: Alpharetta, GA
bevel cut vs straight cut?????? - Similar Threads | ||||
bevel cut vs straight cut?????? | savagebeast | 2.2 Scale Rigs | 2 | 12-18-2012 05:49 PM |
To cut or not to cut? Honcho boggers what do you guys think? | Butcherinhd | Tires and Wheels | 31 | 11-22-2012 09:34 PM |
*** proline flat irons to cut or not to cut you tell me *** | Cmace23 | Tires and Wheels | 14 | 01-21-2012 12:33 AM |
Mudd Slingers to cut or not to cut? | muddbogger | Tires and Wheels | 19 | 04-24-2010 01:26 AM |
