04-25-2017, 09:30 PM | #1 |
Pebble Pounder Join Date: Feb 2017 Location: SoCal
| New driveshaft bearing cover idea
Hi guys. Been doing some stuff to the XL, including a new idea for some rear driveshaft bearing protection. (Might work on the front, too, but I haven't figured that out yet.) I'm using a black nitrile rubber oil shaft seal: 15mm x 26mm x 7mm. I had to shave it down a bit to make it fit without too much friction. There's a metal ring in the rubber that you can grind down further depending on your need. These things are cheap : under 5$. I used electrical tape wrapped tightly to form a seal on the outside of the oil shaft seal, and covered it with a zip tie to keep it in place. Here's pics: Sent from my iPhone using Tapatalk |
04-25-2017, 09:35 PM | #2 |
| Re: New driveshaft bearing cover idea
Here's my setup on the XL. All red metal is from Dhawk. Sent from my iPhone using Tapatalk |
New driveshaft bearing cover idea - Similar Threads | ||||
Outer bearing cover stuck in vanquish hub help! | g04lucas | Axial Yeti | 3 | 04-13-2016 12:04 PM |
I don't understand why there are bearing grooves but no bearing Can go? | Mysterious | Axial XR10 | 12 | 01-14-2013 03:21 PM |
A cover for the battery in back? plate that will cover the rear bed? | davidq19 | Axial Wraith | 7 | 01-28-2012 11:24 PM |
