01-13-2013, 08:34 AM | #1 |
Quarry Creeper Join Date: Nov 2011 Location: Thunder Bay, Ontario
| I don't understand why there are bearing grooves but no bearing Can go?
Hi, I'm putting together the rear axle and I'm looking at the inside mold of the axle. At the outer ends there appears to be a groove for a small bearing. But the actual axle shafts that go through have a little circular ridge around them that prevent a bearing from being slid down to that groove inside the axle. The instructions do not appear to show a bearing being put inside the actual at the ends. But I'm confused why there appears to be a groove molded in there for bearings. I just want to confirm I'm not missing something. Does a bearing go at the outer edge of the axle in that groove or does it not? If it does the heck do you get it over the axle shaft? Sent from my iPhone using Tapatalk |
01-13-2013, 08:59 AM | #2 |
Nevermind, I just answered my own question, it's so you can pull the axle shafts out without opening the axle. Same as the other axle. Sent from my iPhone using Tapatalk |
01-13-2013, 01:04 PM | #3 |
Quarry Creeper Join Date: Jan 2011 Location: westminster
| Re: I don't understand why there are bearing grooves but no bearing Can go?
That's because you're using a front axle housing for the rear, if this were the front that bearing would hold the universal. |
01-13-2013, 01:54 PM | #4 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: I don't understand why there are bearing grooves but no bearing Can go? |
01-13-2013, 03:24 PM | #5 |
Pebble Pounder Join Date: May 2008 Location: Mobile, AL
My guess is that they molded the bearing race in the rear housing so you have the option of rear steer if you want it, you just need the front C hubs, knuckles and universals to make it work. lol Jake |
01-13-2013, 05:07 PM | #6 |
Rock Crawler Join Date: Jul 2012 Location: Long Island, NY
I run bearings there. Can't hurt.
01-13-2013, 05:22 PM | #7 | |
| Re: I don't understand why there are bearing grooves but no bearing Can go? Quote:
But still the bearing is to hold the universal if you were using rear steer Last edited by sidehill; 01-13-2013 at 05:25 PM. | |
01-13-2013, 06:38 PM | #8 |
01-13-2013, 07:02 PM | #9 |
01-13-2013, 08:47 PM | #10 |
RCC Addict Join Date: May 2012 Location: Folsom
On the rear axle the bearings sit on top of that flange on the axle and meet up at the end of your rear lock outs. There is a little slop in the rear axle side to side, you can put a tiny shim between the flange and the bearing to clear that up. |
01-14-2013, 06:15 AM | #11 |
01-14-2013, 01:40 PM | #12 |
RCC Addict Join Date: Aug 2009 Location: Earth?
It has to do with the cutting brake that never came out.
01-14-2013, 03:21 PM | #13 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
You could put a split bronze bearing in there |
I don't understand why there are bearing grooves but no bearing Can go? - Similar Threads | ||||
Bearing size | punkfan | General Crawlers | 7 | 11-06-2011 04:55 PM |
Bearing question | Beerman Crawler | EnRoute Berg | 1 | 07-23-2010 09:29 PM |
T/F One way bearing and more? | snakeman | Kyosho Crawlers | 4 | 03-21-2005 09:17 PM |
