07-12-2017, 07:57 PM | #1 |
Rock Stacker Join Date: May 2017 Location: Camden
| Mod 1 gearing for yeti xl
Is there anyway to get mod 1 gearing in the yeti xl? 32 pitch gearing is working great but I want to go more aggressive in my gearing options. Sent from my iPhone using Tapatalk |
07-12-2017, 08:42 PM | #2 |
Quarry Creeper Join Date: Mar 2015 Location: florida
| Re: Mod 1 gearing for yeti xl
Yes all you need is a sleeve that will attach to the YXL slipper shaft like what Robinson racing has, that will accommodate the spur gear and slipper clutch of another brand of your choice. Maybe you can just buy the sleeve from Robinson racing and modify that to fit other Mod 1 setup. Or you can use the YXL clutch setup and modify a mod 1 spur gear so it can accommodate the YXL slipper pad and the 5 x 11 x 4 mm spacer or bearing. BTW, and you may already be aware, Mod 1's diameter is teeth + 2 mm so YXL's 68T 32P spur gear is 55.56 mm which is equivalent to 53T in mod 1. Good luck with your search.
07-13-2017, 07:05 AM | #3 | |
| Re: Mod 1 gearing for yeti xl Quote:
Thanks for the reply! I was researching all last night and I couldn't really find anything. Do you have part numbers to the parts in which you speak of? Sent from my iPhone using Tapatalk | |
07-13-2017, 10:17 PM | #4 | |
07-13-2017, 10:19 PM | #5 | |
Thanks a lot brother you're the man for this information Sent from my iPhone using Tapatalk | |
Mod 1 gearing for yeti xl - Similar Threads | ||||
Gearing for Yeti with H/Wing 4000kv | byrnieman | Axial Yeti | 9 | 09-14-2016 01:05 PM |
Yeti gearing quetion. HELP! | honchoscaler | Axial Yeti | 4 | 11-02-2015 07:39 AM |
Yeti Gearing | Keola808 | Axial Yeti | 2 | 04-03-2015 06:10 PM |
yeti gearing on 2s | tuba6869 | Axial Yeti | 4 | 02-09-2015 03:50 PM |
gearing for scx10 with yeti motor | cammok5 | Axial SCX-10 | 5 | 11-07-2014 07:36 PM |
