09-16-2014, 09:11 PM | #1 |
Newbie Join Date: Nov 2013 Location: philippines
| Rtr=ready to replace???
Just want to share this... Does rtr means ready to replace? Coz if i ran the yeti out of the box i would have wasted a perfectly bnew spur gear. Doing a pre run check is always advised. The picture is the gear meshing out of the box. It was so loose... Also openned up the rear diff to add grease. Next will be the tranny then the front gears. |
09-16-2014, 10:21 PM | #2 |
| Re: Rtr=ready to replace???
The first run of any new product is always going to be a little sketchy. I gave mine a quick once-over while charging the batteries and found just a few minor things that needed attention.
09-16-2014, 10:29 PM | #3 |
I havent ran my yeti yet...still gonna open up the tranny and front diff. Just to make sure. That is why i personally prefer a kit vs a rtr
09-16-2014, 11:03 PM | #4 |
Rock Stacker Join Date: May 2011 Location: WA
my spur mesh was a little off, wheel nuts were a little loose, need loctite on front trans output, and my servo horn came a little loose after a few runs. thats all i have had so far. did loose a hub on the 2nd run. but had spares. Rob |
09-17-2014, 12:31 AM | #5 |
Quarry Creeper Join Date: Jan 2013 Location: Vancouver, B.C.
I've broken 5 rear hubs only using 2 charge of a 2s. I also lost a driveshaft pin (The one under the motor). I had done a bolts check before run and even put silicon grease in the front diff. The hubs are garbage and I had to order some slw to replace them, at that rate I break 1 hubs at each half 2s pack. (maybe its worth mentioning that I actually drive the truck in rocks since its a rock racer.)
09-17-2014, 09:20 AM | #6 |
Rock Stacker Join Date: Jul 2014 Location: Gilroy, CA
When I noticed almost no grease on the rear diff, I pulled the transmission. Same deal. Greased both with VP blue grease
09-17-2014, 09:22 AM | #7 |
I also tried filling my front diff with 100k diff fluid. Leaked all over. Will have to cleanup and silicon it I guess. Is there a better way?
09-17-2014, 09:28 AM | #8 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
The manual clearly says...check screws/pins before 1st run....
09-17-2014, 12:15 PM | #9 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
But the box says "ready to run" right now. Common sense would be check screws. . . But when you see Rtr, you think axial wasn't lazy when they put it together.
09-17-2014, 12:35 PM | #10 |
Not enough whining in here. This "my RTR is poopy" crap is getting old. Quit being wussies and figure sh#t out! I just got a new "kit" from Cross-RC with assembled axles and transmission, body is build it yourself. You think I bolted those axles and trans up and took off? No, opened the parts up to see what was what, did what I had to do, put it back together and kept it moving. I didn't start talking sh#t on the internets cause Uncle Cross-RC didn't grease the axles all the way. |
09-17-2014, 02:33 PM | #11 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
If you want a truly rtr out of the box then just stick with a plain old traxxas. The stuff they make for the most part you can put a battery to it and drive out of the box. Axial trucks are more geared towards people that are experienced with rc stuff and enjoy working and modding things. I'm sure they will address a few issues that seem to be common with the yetti but even when you buy a rtr scx it can use some tweaks out of the box. That is what makes scale trucks so much more fun then the boring stampedes and slashes that all look and drive the same
09-17-2014, 07:29 PM | #12 |
For people who are new to the hobby its more likely that they will run rtrs right away without doing pre run checks coz its says ready to run anyway....But new or old in this hobby, its definitely worth the time to check vital parts/components prior to running...
09-19-2014, 05:57 PM | #13 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
I say double check everything out of the box, take it apart, put it back together, if you like or not but at least you get a feel of what does what and how the parts works. Also at the same time if you think it needs a little bit more of grease here and there and it will make you feel better when running your rig.. |
09-19-2014, 06:59 PM | #14 |
Lets call it for what it is compared to other axial products... Slapped together. Maybe the other axial are ok since they don't run as much power, but I never had to replace parts after 5 minutes with any of my other axial or any other brand products... Beside my 2 Team Durango SC. (Like Team Durango, the YETI is extremely well engineered but also suffer from some questionable materials choices on the wrong parts.) -Best engineered Axial product. -Poorly slapped together. -Questionable material choices on critical parts. If I could only afford the stock YETI and no fix/upgrades, I think I'd complain quite a bit too. I'm a huge axial fan but I won't lie about how I feel. (FYI I'm 1200$ Canadian deep in my YETI so far just to stop it from breaking and turn properly.) |
09-19-2014, 07:45 PM | #15 |
| Re: Rtr=ready to replace??? |
09-19-2014, 08:54 PM | #16 | |
| Re: Rtr=ready to replace??? Quote:
wtf have you broken to have already sunk $1200 Canadian into it? | |
09-19-2014, 11:10 PM | #17 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
Rtr=ready to replace??? - Similar Threads | ||||
getting my rtr rubicon 3s ready | Justin82 | Axial SCX-10 | 46 | 01-08-2014 10:35 AM |
