09-20-2014, 01:40 PM | #1 |
Pebble Pounder Join Date: Jan 2014 Location: Reynoldsburg
Hello all, looking to gather some electronics for a yeti and I am curious. I have several 6s 1300mah lipos from rc helicopters and wondered if the yeti will run well on 6s 1100kv w/ a MMP and the ckrc upgraded drive train? Also, which pinion? This is the motor in considering, but concerned about the motor shaft diameter. RC OMG Co., Ltd. |
09-20-2014, 01:43 PM | #2 |
| Re: 6s crazy?
Weight seems spot on! |
09-20-2014, 01:47 PM | #3 |
Rock Crawler Join Date: May 2012 Location: Washougal
| Re: 6s crazy?
Only one way to find out I had a Tekin T8 1700 kv bolted up in mine last night but thought better of it. Might be fun for that WOW factor but would break something within minutes how I drive. That motor you linked has the right KV for 6s but not sure if it hold up with that kind of voltage. |
09-20-2014, 02:19 PM | #4 |
| Re: 6s crazy?
For me it wouldn't really be for wows, rather the fact I already have the batteries, also temps should very low...
09-20-2014, 02:20 PM | #5 |
| Re: 6s crazy?
Im no motor expert, but I'll try to dig and find out if the motor is compatible w/ 25V.
09-20-2014, 02:23 PM | #6 |
| Re: 6s crazy?
Actually I have a 1320kv out runner motor that is made for a 6s application...
09-20-2014, 03:37 PM | #7 |
Quarry Creeper Join Date: Mar 2013 Location: Pilipinas
| Re: 6s crazy?
Try it? Let us know, with pics. Curious.
09-20-2014, 03:57 PM | #8 |
| Re: 6s crazy?
Actually, its not sensored and I want that low end control. Is that contradictory considering the high torque of low kV?
09-20-2014, 04:00 PM | #9 |
| Re: 6s crazy?
I'm looking at some other options, theres a Novak 1550kv listed w/ max rpm of 50000, so at 25V, it'd be right there. Looking at other options as well.
09-20-2014, 04:10 PM | #10 |
| Re: 6s crazy?
Running a lower KV motor on higher voltage will give you longer run times and cooler running temps if I remember correctly. Been a few years. |
09-20-2014, 04:33 PM | #11 |
| Re: 6s crazy?
I went 3s to 6s on 450 size helis and it was a change I'll never regret. Lower battery and motor temps. ESC too. I don't know about run time, we just cranked up the rpms.
09-20-2014, 05:06 PM | #12 |
| Re: 6s crazy? |
09-20-2014, 05:43 PM | #13 |
OK, think I found my motor. Tenshock X211 Max Voltage is 42V! http://s1049.photobucket.com/user/ma...d682d.png.html |
6s crazy? - Similar Threads | ||||
Crazy ? | shwng1973 | Electronics | 1 | 06-29-2012 07:53 PM |
ax-10 crazy turned xr-10 crazy | ax-10 crazy | Axial XR10 | 105 | 02-21-2012 10:15 PM |
Am I crazy? | kmoore | General Scale Talk | 4 | 10-12-2011 07:54 AM |
crazy video and pictures of a slash vs airbag crazy | josh hayes | Non Crawler RC's | 8 | 07-01-2009 02:56 PM |
