Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Front bulkhead warped??
Old 10-02-2014, 07:39 PM   #1
Default Front bulkhead warped??
So while wrenching I noticed my body posts have a slight rearward lean to them. It appears like my whole bulkhead was bent back. (The body posts make it look extreme)
However I can't see a smoking gun as to what is bent or loose to be causing this. It doesn't seem to affect anything other than the body so I guess I have two questions...
1) Do I need to take apart and figure out if anything is wrong?
2) What would the likely culprit be?
I did take off the front diff to put some grease in, but I didn't overtighten anything that would cause this and no extra hardware. I did have a slight front end hit that might account for the bend but again I can see any obvious or even vague damage/bend spots.
Aebous is offline   Reply With Quote
Old 10-03-2014, 05:45 AM   #2
Default Re: Front bulkhead warped??
I'm guessing it's the shock tower
AWraith build is offline   Reply With Quote
Old 10-03-2014, 05:59 AM   #3
binaryterror's Avatar
Mine go slightly back, the stock posts are super bendy, like bendy straws if you let it sit upside down on them.
I wouldn't worry.
binaryterror is offline   Reply With Quote
Old 10-03-2014, 08:48 AM   #4
OK, thanks for the responses.
Front bulkhead warped?? - Similar Threads
warped gears ! leon Losi Micro-Rock Crawler 15 12-22-2009 07:15 AM
Revo Aluminum Bulkhead xlazyb Non Crawler RC's 7 02-20-2008 06:29 AM
