10-04-2014, 10:56 PM | #1 |
Rock Stacker Join Date: Sep 2014 Location: Ermergerd
| Anybody running a Savox?
I picked one up and am just wondering if yall get the weird buzzing sound... I was told I needed a BEC so I picked one up. Just waiting to install it... It's fast as all get out, that's for sure!
10-04-2014, 11:22 PM | #2 |
Newbie Join Date: Sep 2014 Location: olympia
| Re: Anybody running a Savox?
No weird buzzing noise with mine but I did have to add a Glitch buster capacitor.
10-04-2014, 11:35 PM | #3 |
Rock Stacker Join Date: May 2011 Location: WA
the buzzing is normal from my experience. just the servo keeping center IIRC
10-04-2014, 11:37 PM | #4 |
RCC Addict Join Date: Oct 2012 Location: Norcal
I run Savox 1230's in all my rigs, digital servo's make that buzzing sound because there trying to find center. It's nothing to worry about, it's standard. Lift your rig off the ground and flick your steering and most of the time it will stop. What Savox are you running? |
10-05-2014, 04:27 AM | #5 |
Newbie Join Date: Sep 2014 Location: Haltern am See - Germany
Hello all, Had that issue as well! I installied a Savox 2270 (with the plan to install a BEC later) on the existing ESC circuit and under steering the car stopped Running. I also have a GearHead Trail torch on the Receiver which draws little power. With the stock Tactic servo the steering sucked. Even after replacing all steering Parts to Metal. Received a new Hacker Tensoric8.2 ESC yesterday and installied it. On a quick wiring i noticed the steering is ultra fast and has power even without an external BEC. Doing Some more ligths wiring and Thenée make a test Drive. I checked the stock ESC specs for the BEC. 5V 2amp..... Now that explains it all to me! Feed your servo and it works rigth:-) Best regards, Tiki/Germany |
10-05-2014, 10:35 AM | #6 |
1258tg is what I'm running. Was told a bec would help so I hot one. Going to finish up the install today and use the Castle link to up the voltage to 6... I watched a ton of videos and heard the buzzing however, this thing could still use the 6 volts for a little more steering power...
Anybody running a Savox? - Similar Threads | ||||
Running Savox Servos Now! | alexchen86 | Electronics | 14 | 05-07-2013 11:27 AM |
Ya'll running 35T motors, what pinion are you running? | concretejungle | Axial XR10 | 9 | 03-11-2012 08:18 PM |
Those running 3s Lipo - what are you running, what do you like? | goldmember | Team Losi Comp Crawler | 41 | 09-19-2009 06:39 AM |
