10-06-2014, 05:25 PM | #1 |
Newbie Join Date: Aug 2014 Location: Louisville
| Servo questions regarding voltage an wiring
So I was reading the paperwork that came with my Hitec 7954sh servo... it reads like it is only compatible with 2S lipos, anybody have experience or advice? I do have a castle BEC that will be installed and I really only want to run 3S on this car without smoking the electronics.... Kinda new to the rc scene and any/all help will be appreciated from all you yeti yodas. |
10-06-2014, 05:51 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Servo questions regarding voltage an wiring
Set the BEC to 7.4V (or a little lower), then install it. You can now safely get full power to the servo and disable the ESC's internal bec while running 3s. Keeps your servo and esc happy
10-06-2014, 06:33 PM | #3 |
Rock Stacker Join Date: Sep 2014 Location: Delta
Why wouldnt you want to use the ESCs internal BEC? I will be upgrading to the MMP once I manage to fry the AE-3. The BEC on the MMP is adjustable from 5 to 7 volts. Regardless of Battery voltage. I see so many people in various forums adding a BEC to the MMP still. Why?
10-06-2014, 07:37 PM | #4 |
Rock Stacker Join Date: May 2011 Location: WA
Because the bec in the MMP is only like 3 amps which is not enough for high tourqe servos.
10-06-2014, 07:40 PM | #5 |
So will the BEC fry the MMP eventually?
10-06-2014, 08:21 PM | #6 | ||
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Servo questions regarding voltage an wiring Quote:
Holmes Hobbies LLC Quote:
You need a BEC, and again use the Receiver Bypass. | ||
Servo questions regarding voltage an wiring - Similar Threads | ||||
High voltage servo wiring? | toyota2 | Electronics | 9 | 05-02-2013 11:59 AM |
Wiring high voltage servo? | meatmonkey | Electronics | 6 | 07-18-2010 08:54 PM |
ESC / Servo / BEC Wiring Questions??? | RCholic | Electronics | 1 | 09-18-2007 06:11 AM |
Wiring a voltage regulator for 2nd servo | teamtom | Electronics | 1 | 05-19-2006 12:10 PM |
Wiring a voltage regulator for 2nd servo | teamtom | Tamiya Clod Buster | 0 | 05-16-2006 08:01 PM |
