11-06-2014, 07:12 PM | #1 |
Newbie Join Date: Sep 2014 Location: Osage City
| Yeti Rear Upper Link Contact With Shock?
With the Swaybar Disconnected on my Yeti the axle still can not hardly "flex out" due to the upper link getting bound up in the coilover. Even With the swaybar connected as the rear axle starts to flex the link is already contacting the spring. Is anybody else having these problems, and would an upper link kit such as the one from vanquish fix this?
02-28-2015, 10:15 PM | #2 |
Newbie Join Date: Feb 2015 Location: San Diego
| Re: Yeti Rear Upper Link Contact With Shock?
i guess not... i have the same question
03-01-2015, 06:49 AM | #3 |
Rock Stacker Join Date: Jan 2015 Location: MD
Yes, the Vanquish uppers will help a lot. They still contact the springs a little,but not bad. The down side is they break very easily if you do any bashing.
03-01-2015, 06:52 AM | #4 |
Rock Crawler Join Date: May 2007 Location: Glendora
| Re: Yeti Rear Upper Link Contact With Shock? |
03-01-2015, 07:02 AM | #5 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
03-01-2015, 08:22 AM | #6 |
03-01-2015, 09:02 AM | #7 | |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
| Re: Yeti Rear Upper Link Contact With Shock? Quote:
VP links will help like others said but you don't have to use the bent links. Straight links are perfect and have no issues of being anywhere near the shocks at full extension or full compression. | |
03-01-2015, 10:03 AM | #8 |
^^ Straight up/down isn't a prob. It's during articulation. I had straight uppers on mine and they still would contact the springs a little.
03-01-2015, 10:16 AM | #9 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Just looking at the pics above, doesn't seem like the straight links would even come close to making contact during articulation. Guess it depends, too, on the location of the mounting points on the axle.
03-01-2015, 10:19 AM | #10 |
03-01-2015, 11:21 AM | #11 |
Looks like you have plenty of room for sure. Must have to do with your lowers and your lower shock mounting. Or maybe the axle end height of the uppers? My Centered VP axle with stock or STRC lowers and straight uppers hit the the springs, didn't matter what hole the shocks were mounted in. Are those UC Fab lowers?
03-01-2015, 12:19 PM | #12 | |
They are VP Trailing Arms. | |
Yeti Rear Upper Link Contact With Shock? - Similar Threads | ||||
Move Upper Rear Shock Mounts? | SCX10Dingo | Axial SCX-10 | 12 | 07-22-2013 07:46 PM |
Lipo Rear Upper Link??? | BMFOTP | Electronics | 5 | 05-19-2009 11:00 AM |
Rear Upper Link Mount Mod | EeePee | Axial AX-10 Scorpion | 24 | 09-12-2007 06:19 AM |
