12-03-2014, 07:57 PM | #1 |
| New battery faster in reverse
Evening guys. So I am trying a new turnigy 5000 35c on the bench before tomorrow and in reverse it balloons the tires but not in forward. Never seen this before. Nothing else was touched. Just the battery. Really scratching my head on this one. Any ideas?
12-03-2014, 07:59 PM | #2 |
| Re: New battery faster in reverse
What motor are you running? Edit, did you reverse the throttle by chance? |
12-03-2014, 08:08 PM | #3 |
Stock motor and esc. Reverse the throttle? I wouldn't even know where that is.
12-03-2014, 09:35 PM | #4 |
Quarry Creeper Join Date: Sep 2012 Location: Orange County, CA
You can also try swapping any one of the A, B or C wires going from the ESC to the motor. It's a sensorless stock system, and that's usually the issue Sent from my iPhone using Tapatalk |
12-03-2014, 09:54 PM | #5 |
Winner & Rich, Thanks for the replies. I checked the ABC connections form the motor just in case and they were all in the correct spots. So try A wire in C and if not then A in B? Is there a combo i should start with? |
12-04-2014, 12:45 AM | #6 | |
| Re: New battery faster in reverse Quote:
I don't believe it matters much. Swap two and plug the battery back in. Check the throttle. Sent from my iPhone using Tapatalk | |
12-05-2014, 11:59 AM | #7 |
Rock Crawler Join Date: Jan 2009 Location: Great NorthWest
if that doesn't work. Try to recalibrate the ESC endpoints to the transmitter.
12-24-2014, 01:18 AM | #8 |
did it get fixed? |
12-24-2014, 07:13 AM | #9 |
rockslyder, Yes. Switching the A wire in C slot solved the issue. I don't have any experience with big power but the motor runs well and within temps so for now i am pretty happy with it. Very fun rig. |
New battery faster in reverse - Similar Threads | ||||
reverse is faster? | EMUTT | Electronics | 11 | 08-13-2011 08:28 AM |
Reverse is faster | SinCity | Axial SCX-10 | 13 | 10-23-2010 09:38 PM |
Going faster in reverse | motojeep | Axial AX-10 Scorpion | 4 | 03-17-2010 07:55 AM |
Faster in Reverse? | SpyderMonkee | General Crawlers | 2 | 03-17-2008 12:19 AM |
Faster in Reverse | nascarkeith | Electronics | 8 | 01-30-2007 04:13 PM |
