12-22-2014, 03:05 PM | #1 |
RCC Addict Join Date: Aug 2012 Location: Philippines
| SSD Knuckle clearance?
Has anyone compared the SSD Yeti scale knuckles to the OE and VP parts? I'm wondering if there are any differences in clearance... |
12-22-2014, 03:32 PM | #2 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SSD Knuckle clearance?
The main clearance issue with Exo and Yeti knuckles is the arm. The SSD Yeti knuckle steering arm actually has a little more clearance than the stock Yeti knuckle. |
12-22-2014, 03:46 PM | #3 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
Mine fit perfect, nothing hitting or binding and to me they are a much beefier than the Exo knuckles.
12-22-2014, 03:49 PM | #4 |
Rock Crawler Join Date: Sep 2011 Location: truckee
Those look nice. I need to find a set in black...
02-04-2015, 12:26 AM | #5 |
I joined the Band! Join Date: Sep 2012 Location: Lake Forest
That would be something to note in the details section when ordering. Nice knuckles but I ordered stock length links and then had to order adjustable turnbuckles after the fact. So I'm out 25 bucks.
02-04-2015, 12:27 AM | #6 |
I'm actually installing these as I type this.
02-04-2015, 06:45 AM | #7 |
Rock Stacker Join Date: Jan 2008 Location: Escondido
Any feedback?
02-04-2015, 07:08 AM | #8 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
| Re: SSD Knuckle clearance? |
02-04-2015, 08:19 AM | #9 | |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: SSD Knuckle clearance? Quote:
Installed mine the other night and after making my turnbuckles the same length as the OE parts, I had to shorten them to push the tow out some. Very nice quality parts, though! Last edited by Sh0rtBus; 02-04-2015 at 08:21 AM. | |
02-04-2015, 09:38 AM | #10 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
Bearings are a tad loose in my SSD's. Not perfect fit like VP or STRC's. So there is a little wheel slop. I'll try some other bearings and see what happens. Clearance is good.
02-04-2015, 10:06 AM | #11 |
| Re: SSD Knuckle clearance? Which bearings? My outers slide in pretty easy, but are by no means loose. And the inners I had to apply a pretty good amount of force to get in to place.
02-04-2015, 10:28 AM | #12 |
Stock Axial bearings that came w/kit. Inner bearing only. I'm gonna swap out with some Protek and see if that cures the slop.
02-04-2015, 12:29 PM | #13 |
I ordered dlux ti links assuming the ssd knuckles were the same as oem. There are a few others that had my same problem. Just saying they should let ppl know they require turnbuckles instead of ti links. That way ppl don't have to pay twice. Got the traxxas turnbuckles on the way. Thanks for the link.
02-04-2015, 02:17 PM | #14 | |
02-04-2015, 04:25 PM | #15 |
Pebble Pounder Join Date: Mar 2008 Location: sherbrooke
they look realy good but seems like some people look to have some issu with them will wait for mine to see what happens
02-04-2015, 05:27 PM | #16 | |
The STRC caster blocks require a sitter camber link. The SSD knuckles required shorter steering links with this combination. Cutting off a couple steering link threads is necessary with the stock kit turnbuckles. | |
02-04-2015, 08:15 PM | #17 |
Pebble Pounder Join Date: Dec 2013 Location: brockville
02-04-2015, 10:30 PM | #18 |
Mine were toed in about 10 degrees with "hella camber"
02-05-2015, 03:31 AM | #19 | |
We will add a note about the toe in onto the product page to make it clear. | |
02-05-2015, 12:52 PM | #20 |
After replacing bad inner bearing all is good. This is a great product and competitively priced. Heavy duty and made well and perfect tolerances. I had no problems w/stock links and ends (Kit version). Plenty of room for adjustments. Thanks SSD for a quality product. |
SSD Knuckle clearance? - Similar Threads | ||||
New 3racing High Clearance Knuckle. | QIK-RX4 | Axial AX-10 Scorpion | 127 | 07-14-2014 05:42 PM |
3s racing High Clearance Knuckle | m1009cucv | Axial SCX-10 | 11 | 04-21-2014 02:46 PM |
aluminum knuckle 1.9 clearance.. wtf???? | mycrors7 | Axial SCX-10 | 8 | 05-02-2011 05:59 PM |
RCBros hi clearance knuckle weights | Erik D_lux | Team Losi Comp Crawler | 12 | 03-10-2011 05:54 PM |
high clearance knuckle | saturnsl89 | Tamiya CR-01 | 7 | 01-12-2011 04:33 AM |
