02-11-2015, 09:46 AM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Rocky Mountains
| 2wd prerunner Yeti?
Hi guys -- my apologies if this has already been covered (did a search and couldn't find a similar concept), but I'm wondering how you Yeti owners think the platform would drive as a 2wd-only prerunner? I was thinking of using it as a basis for a prerunner build, with Twin Hammers rear trailing arms to shorten the wheelbase a bit. Any thoughts? Thanks! Steve |
02-11-2015, 10:31 AM | #2 |
| Re: 2wd prerunner Yeti?
Would make a great platform. Do it |
02-11-2015, 10:34 AM | #3 |
I look forward to seeing the build!
02-11-2015, 04:29 PM | #4 |
Newbie Join Date: Jan 2005 Location: Houston, Texas
I had a dog bone fall out a couple weeks ago, and didnt want to go home yet. So i took the other side out also, making it a 2 wheel drive...It has no traction! Even if you pump the throttle to get it up to speed its a little hard to control. Just my 2cents. I dont know what all your planning on doing to the chassis to make it prerunner but keep this in mind. I am still subscribing, this should be a cool build.
02-11-2015, 04:33 PM | #5 | |
| Re: 2wd prerunner Yeti? Quote:
He will need to do a lot of test and tune with shock angles, oil, springs, link position, foams, etc. But I certainly see it as a possibility of being a great performer once he gets it all figured out. Everything is there to make it work, it is just finding the right configuration. | |
02-11-2015, 05:04 PM | #6 |
Rock Crawler Join Date: Mar 2014 Location: Dallas, Texas
One big issue will be weight over the rear end. I agree that it will likely not perform well. I have a B4.1 RC 10 that I have a Speed Passion 5700 KV motor in. I have to monkey around with the suspension to account for the length of the 550 motor can. That said, it is a freaking beast, it is heavy in the a$$ and gets respectable traction under acceleration, but it is terrible under braking. I imagine your prerunner would be the same. Why not just pick up a beater off of ebay and do it that way? An older RT10T or for that matter, and RC10 as I have works very well and is lightning fast and incredibly responsive.
2wd prerunner Yeti? - Similar Threads | ||||
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
2wd slash/2wd stampede trannys | hotwheels000 | Chit Chat | 3 | 07-14-2014 07:59 AM |
Custom tubed 2wd Prerunner | jamesbernatchez | Non Crawler RC's | 43 | 05-21-2008 01:01 AM |
