04-06-2015, 09:53 AM | #1 |
Pebble Pounder Join Date: Mar 2015 Location: france
| Vanquish SLW Wheel Hub Vs axial stock parts
Hi all, I would like to change those axial plastic wheel hubs for vanquish parts. If I want to keep the same front & rear width with the axial stock wheels what part number should I go for ? thanks LV |
04-06-2015, 10:27 AM | #2 |
Quarry Creeper Join Date: Dec 2014 Location: Northern VA
| Re: Vanquish SLW Wheel Hub Vs axial stock parts
For stock width: 225 for the fronts 725 for the rears Don't forget the 4-40 screws. |
04-06-2015, 11:29 AM | #3 |
Thanks hobbez84
04-06-2015, 01:36 PM | #4 |
Pebble Pounder Join Date: Jan 2015 Location: USA!!!
I just did this upgrade myself. I found the stock axial plastic ones would warp and bend so the wheels would wobble. Waiting on rebuild parts for my MIP shaft and then I'll be able to test
04-06-2015, 02:20 PM | #5 |
Rock Stacker Join Date: Feb 2015 Location: North Bend
Thanks OP for asking. I was searching the forum for the same thing. Does anyone know who has these online? I checked RPP Hobby and they are out of stock. |
04-06-2015, 02:57 PM | #6 |
Easiest way to get these...go with the CKRC kit. Has everything you need. CKRC Crawlers, YWF1 - Yeti Wheel Hub Fix Kit TCS Crawlers seem to have them in stock as well. http://www.tcscrawlers.com/SearchRes...ch=slw&Submit= Amain has the 225s in stock, along with the very nice black versions. Search for 'vanquish slw' - AMain.com Hope that helps |
04-06-2015, 07:36 PM | #7 | |
| Re: Vanquish SLW Wheel Hub Vs axial stock parts Quote:
04-07-2015, 11:55 AM | #8 |
oups ! found the same post : Axial Yeti Stock Hub Kit Last edited by le varan; 04-07-2015 at 11:57 AM. |
04-07-2015, 12:02 PM | #9 |
CKRC kit is a really good bargain ! |
04-07-2015, 12:25 PM | #10 |
Newbie Join Date: Dec 2010 Location: Roanoke/ where ever I'm working
Loc tight, loc tight, loc tight!!! On the 4-40 screws and the wheel nuts and check the wheel nuts often. Other than that I am happy with the swap.
04-18-2015, 02:24 AM | #11 |
Just got my kit from a friend who flew back to france yesterday ! 20150417_181107 by le.varan, on Flickr 20150417_191658 by le.varan, on Flickr 20150417_190303 by le.varan, on Flickr Had to use a 2.8mm drill bit to enlarge the current hole, due to the non metric srews, were to small. Turned it by hand. 20150417_190924 by le.varan, on Flickr Do not forget to use loctite and don't tighten them to hard the plastic of the rims are pretty soft ! |
05-12-2015, 11:43 PM | #12 | |
05-12-2015, 11:57 PM | #13 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
good stuff an info Mine haven't broken yet but when it does this is my next purchase...
Vanquish SLW Wheel Hub Vs axial stock parts - Similar Threads | ||||
Vanquish SLW wheel hub wheel mounting screws? | chevyfan3 | Tires and Wheels | 6 | 05-16-2013 04:43 PM |
Vanquish Currie Axles and SLW hub question | buddamonk | Axial SCX-10 | 6 | 03-11-2013 09:35 AM |
Vanquish slw hub size | XJkid93 | Tires and Wheels | 5 | 06-24-2012 05:02 PM |
Vanquish SLW V3 on Bully Axles which hex hub size???? | vodka child | RC4WD Bully | 17 | 07-16-2010 10:43 AM |
