05-11-2015, 02:41 AM | #1 |
RCC Addict Join Date: Aug 2014 Location: Virginia, Near DC, USA
| Torque-steer
I've gotten my Yeti to handle almost the way I want, but there's one last thing that's causing me some grief: torque steer. When I hit the throttle hard, the vehicle veers to one side. I've checked the wheel bearings and they're not binding, so it must be something about the way the suspension articulates under hard acceleration that's causing the torque-steer. I can counter-steer, but only if I remember it's a problem and I catch it in time. Has anyone else come up with a good solution for this? For the record, I have both diffs open, the stock swaybar in the rear, and the stiffest EXO swaybar in the front. |
05-11-2015, 11:26 AM | #2 |
Newbie Join Date: Dec 2013 Location: Aurora
| Re: Torque-steer
Have not had that problem... Mine is locked front and rear, and under throttle it goes perfectly straight. Even when the front was open, it went straight....
05-11-2015, 11:40 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Torque-steer
Could be from the chassis rear link placement, move those to see. Could also be too light of a sway bar in the back. I'd remove the front sway too just to see what that provides, but shouldn't in a hard launch change the torque. |
05-11-2015, 12:00 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
| Re: Torque-steer
It's because of the open diff in the rear. When you hit the gas one rear wheel is trying to spin faster than the other. A locked diff would solve it. It's kinda like a powerful fwd car with an open diff, when you hit the gas it tries to pull steering wheel to one side. Last edited by CamaroTom; 05-11-2015 at 12:03 PM. |
05-11-2015, 12:38 PM | #5 |
| Re: Torque-steer
Locking the rear diff isn't really an option for my intended terrain and driving style. I would've thought the 100k diff oil would keep it in-check, but perhaps I need thicker oil in the rear diff. I wish Associated would re-stock their 200k oil already; I tried the 500k stuff and it's way too thick. How would changing the rear link position affect this problem? I'm not familiar-enough with how four-link suspensions work for the suggestion to make sense to me. |
05-11-2015, 12:59 PM | #6 |
| Re: Torque-steer
I'll do some research but how do you run an "Open Diff" in the back? Ditch the locker and diff housing for a front one? Would that even work?
05-11-2015, 01:05 PM | #7 |
| Re: Torque-steer
This is pretty easy if you know a few things about open diffs and solid axles and suspension stuff. The driveshaft is rotating. The pinion is trying to climb the ring gear. There is resistance. That can be seen by the chassis leaning over. That then means weight has been transferred. That means one tire is not on the ground as much as the other. Open diff transfers power to the wheel that is more willing to spin. That mean speed difference between tires. That means torque steer.
05-11-2015, 01:28 PM | #8 | |
| Re: Torque-steer Quote:
Anyway, it's not completely open, that would be if it were packed with slippery grease. I'm running mine in a limited-slip configuration with 100k silicone oil providing resistance against diffing-out. | |
05-11-2015, 01:30 PM | #9 | |
05-11-2015, 01:42 PM | #10 |
| Re: Torque-steer
Anti squat, which has an affect on what the chassis does, and the axle. It is your civic duty to try the other two positions. |
05-11-2015, 01:51 PM | #11 |
| Re: Torque-steer
I move those squat links all over and you can learn a lot and really change handling. I also use the Dlux truss, for even more adjustment and a way better axle mount point (stock is too low). |
05-11-2015, 02:09 PM | #12 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: Torque-steer
Torque steer can be mitigated by removing torque...... Hey, I'm just stating the obvious - HORRIBLE option, but an option all the same - LOL |
05-11-2015, 02:16 PM | #13 | |
I think I may have heard of that part a while ago in relation to the Twin Hammers, but I can't remember for the life of me who makes it or where it's sold. Link? Last edited by fyrstormer; 05-11-2015 at 02:18 PM. | |
05-11-2015, 02:22 PM | #14 |
| Re: Torque-steer
It's not that minor and no, I won't. Increase or decrease, you don't even know. Learn, my friend. It's good for you. Try em both, experience it. Dlux makes Dlux products. Vendor's section. Maybe Binaryterror will be more helpful. |
05-11-2015, 02:34 PM | #15 |
| Re: Torque-steer
I found the truss on SuperShafty. I can't tell just by looking; how much does it raise the rear upper-link mounts compared to stock? Y'know EeePee, even if I know what the adjustment will do, I can still experiment to confirm whether that adjustment accomplishes what I want it to accomplish. You could tell me which direction to move the links to increase the anti-squat, but I'd still have to try it and see for myself, except I wouldn't be going in blind, with no idea what to expect. Why should I rediscover knowledge that already exists? I get paid to figure out things that other people haven't figured out, I'm not going to waste my time figuring out things other people already know in my free time. Last edited by fyrstormer; 05-11-2015 at 02:36 PM. |
05-11-2015, 02:51 PM | #16 |
| Re: Torque-steer
Well, I managed to find a helpful article online: Tuning 4 Link Rear Suspensions for the Drag Strip So it looks like moving the forward upper-link mounts down will increase the anti-squat effect. Interesting, because I took one look at the kit-stock recommended setup with the forward upper-link mounts in the highest position and I just knew it wouldn't work well. Last edited by fyrstormer; 05-11-2015 at 03:02 PM. |
05-11-2015, 02:55 PM | #17 |
| Re: Torque-steer
Okay, but it's your hobby, no? What's the big deal? I'd really like to see someone go in blind, like I've done, experiment, and learn, and then help others. I can link you to two huge threads here on RCC, one of which I helped a ton of people, but I now like to drop morsels of information and get people to expand themselves. Grow. Fine, here's 2006: Anti Squat and Suspension Tech |
05-11-2015, 03:27 PM | #18 |
| Re: Torque-steer
Don't worry, I have plenty of ways to grow as a person. I do RC as a hobby because it's (usually) *less* stressful than other areas of my life. Experimenting blindly and hoping for a positive result is extremely stressful and not fun at all, because there's all this tinkering involved and I have no idea if it will do any good or end up being a waste of time. I did enough blind experimentation when I was first getting into the hobby. If you're concerned about people parroting information they heard without ever checking to see if it actually works, you don't have to worry about that from me. I disagree with conventional wisdom due to my own personal experience on a regular basis. |
05-11-2015, 03:40 PM | #19 |
| Re: Torque-steer
Sounds good, mate. In the time it took you to respond, you could have tried upper and lower holes. |
05-11-2015, 03:46 PM | #20 |
| Re: Torque-steer
Nope, because I'm at work right now. I'm planning ahead so I can make the most efficient use of my limited time between getting home and doing chores. Anyway, I ordered the rear Dlux truss, so if moving the forward upper-link mounts down a notch doesn't give me the effect I'm looking for (or causes clearance issues with the MIP rear driveshaft), I'll move the rear upper-link mounts up a couple notches instead. Looking at the other truss options available, i.e. Vanquish and STRC, it doesn't look like either of those offer extra mounting points, or even any static additional height. Last edited by fyrstormer; 05-11-2015 at 03:59 PM. |
Torque-steer - Similar Threads | ||||
How can i reduce my torque steer? | Tom94offroaduk | Newbie General | 11 | 01-06-2011 05:34 PM |
triangulate/torque steer | nsg1rc | Newbie General | 1 | 09-14-2008 10:49 PM |
Torque steer - Causes & remedies | crawler4real | General Crawlers | 2 | 09-06-2007 09:12 PM |
Torque steer | Nish | Tamiya TLT Crawlers | 5 | 07-20-2004 03:32 PM |
Torque steer ? | Fishmaxx | General Crawlers | 12 | 06-20-2004 02:39 PM |
