07-24-2015, 05:07 PM | #1 |
I wanna be Dave Join Date: Sep 2004
| Just blew inner rear pinion bearing and...
i just ran my yeti making everything was set for racing sunday and the rear inner pinion bearing went. it prolly took out the ring gear as well. to top it off the set screw to my mip drive shaft is stripped out lol. i read some use an oillite bushing to replace the bearing in there. i was looking forward to racing this weekend too. |
07-24-2015, 06:21 PM | #2 |
Quarry Creeper Join Date: Oct 2010 Location: Nashville TN
| Re: Just blew inner rear pinion bearing and...
thrust bearing mod. look it up in stevec6r's bulletproof yeti thread
07-24-2015, 07:29 PM | #3 |
Newbie Join Date: Jul 2015 Location: Cairns, Australia
If you go the thrust bearing just keep an eye on it. I changed out to one and whilst it is designed to cope with inward and outward pressure it developed some up and down slop after half a pack. This allowed the rear edge of the pinion gear to touch the housing. I've since gone back to a standard bearing which I change out regularly with a new one. |
07-24-2015, 07:38 PM | #4 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Time for a Dlux housing with bigger bearing.
07-24-2015, 07:43 PM | #5 |
| Re: Just blew inner rear pinion bearing and... ShOrtBus I've been thinking about that route. Currently running VP OCP axle and considering changing over to the VP V2 for the bigger bearing. Are those running the bigger inner bearings still having any bearing failures? |
07-24-2015, 08:30 PM | #6 |
what about just using a bushing?
07-24-2015, 08:32 PM | #7 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Bushings wear, it's their job. So they don't explode into the housing, but you'll have slop. Almost immediately. Dlux big bearing, SSD axle, VP V2 axle, or thrust bearing (inner only) are your options IMO. Also make sure you are running Underdrive (43/13) Axial gears for best mesh. Yes you'll be a touch slower but have better mesh. |
07-24-2015, 08:37 PM | #8 |
this yeti is killing my wallet.
07-24-2015, 10:46 PM | #9 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Mini locos from lockuprc! |
07-25-2015, 08:25 AM | #10 |
07-25-2015, 02:58 PM | #11 |
on the dlux page it reads "Axial Wraith housings that have had the bearing area modified for a 5x13 bearing. The bearings are set in the housing so a standard (new) ring and pinion will be just a hair too tight but perfect when broken in. Comes with gear side bearing installed." so no shimming required? |
07-26-2015, 09:26 AM | #12 |
I didn't need to shim mine at all. Or in his Exo case for my Yeti's front. Perfect fit.
07-28-2015, 01:30 AM | #13 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
I've running the thrust bearing mod in my Currie for nearly a year with zero issues and I'm not easy on it.
07-31-2015, 08:49 PM | #14 |
well parts came in today. after cleaning out the axle housing the best fit with no slop was a new bearing. an oilite bushing of the same size was close but it had some slop. i didnt try the thrust washer or the modded housing. if this bearing goes (im gonna check it often) ill prolly go the modded housing way.
07-31-2015, 09:29 PM | #15 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
The D_Lux housing is the way to go....they are tough as nails. One other thing you should consider is your punch control and break strength....I know, I know....just look into it and you may be impressed how it makes your car a little easier to race! |
08-01-2015, 10:59 AM | #16 |
Newbie Join Date: Jul 2015 Location: Ajax
Ive had the same issues with the wraith and ive put traxxas oillite bushings in the diff and driveshaft sides and it works AMAZING!
08-01-2015, 02:14 PM | #17 |
| Re: Just blew inner rear pinion bearing and... |
08-01-2015, 02:29 PM | #18 |
The RC industry went to bearings for a reason...you're limiting your performance and putting a band-aid over the actual problem. But, if you're happy....have at it. |
08-01-2015, 08:52 PM | #19 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
Just blew inner rear pinion bearing and... - Similar Threads | ||||
Rear Pinion Bearing Blew Up Er'thing | relay1 | Axial Yeti XL | 20 | 01-04-2015 04:55 PM |
Blew a pinion | Mnster | Chit Chat | 12 | 11-14-2007 02:56 AM |
I blew my ring and pinion... | toyofast | Chit Chat | 23 | 04-17-2006 10:42 PM |
Blew my ring and pinion!!!!!!!!! | Magic | Chit Chat | 27 | 01-07-2006 12:52 PM |
I blew up my TLT rear!!! | fullmodtxt | Tamiya TLT Crawlers | 5 | 12-31-2004 06:13 PM |
