09-04-2015, 03:58 PM | #1 |
Quarry Creeper Join Date: Jul 2015 Location: Winter Park Colorado, 8000Ft Elevation
| opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti
Most of my order is set but I am still on the fence about this one, https://www.amazon.com/dp/B00XF8B7NI...I3E2DKNV131GII |
09-04-2015, 05:19 PM | #2 |
Pebble Pounder Join Date: Aug 2015 Location: Jackson
| Re: opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti
i run one its a nice unit . have not had any trouble with it .
09-04-2015, 07:56 PM | #3 |
thank you, my order is up around $1600.00 and I want to make sure that even though I am buying on a budget and trying to go middle -of-the-road on a lot of things I would like to stay away from "junk" if possible. I have been doing a lot of reading on other peoples builds and taking notes on what their choices have been. Personal experience is always good for advise. |
09-04-2015, 09:20 PM | #4 | |
Newbie Join Date: May 2015 Location: Commiefornia
| Re: opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti Quote:
Wow, $1600 is quite a nice "budget". I'm currently building my kit and have installed that rack. I did have to shave a little from the center linkage in order to clear the drive shaft, but otherwise it fit perfectly and is very smooth. | |
09-04-2015, 10:05 PM | #5 |
$1600 is like top end. I got all vp for that. lol
09-05-2015, 05:41 AM | #6 |
Rock Stacker Join Date: May 2015 Location: central PA
The YET48G01 Aluminum Graphite Steering Bellcrank is on my wishlist also. I'm just waiting for my kit parts to wear out before upgrading. $1600 middle of the road? Haha. Good one. And now I see they (Hot Racing) also makes an adjustable steering bellcrank. That is definitely something that should have been designed into the Yeti in the first place. Hopefully the Yeti 2.0 (fingers crossed) will have all the little bugs worked out. Last edited by RustyUs; 09-05-2015 at 05:48 AM. |
09-05-2015, 09:07 PM | #7 |
well up to 1850$, this may be getting a little out of control. This is not only for the basics but some extras too like a variety of shock springs, oils, body paints, 2 turnigy batteries, MIP drive shaft, and a lot of GPM. I am going big with the Pro 4 HD, RX 8 Gen 2, and Savox 0240MG My estimated minimum just to get the Yeti running is about 1170$ the balance are the "extras". My house just went under contract today so I should have some play money soon. |
09-05-2015, 09:24 PM | #8 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
Personally I'd use some vanquish over gpm
09-05-2015, 09:28 PM | #9 |
I've got the Vanquish axle housing and lockouts on my list.
09-05-2015, 11:00 PM | #10 |
add the VP trailing arms, sway bars, knuckles, and castor blocks. |
09-05-2015, 11:15 PM | #11 |
Quarry Creeper Join Date: Dec 2014 Location: Northern VA
That savox servo you have spec'd out is for 1/5 scale no? Not entirely sure a 5th scale servo would fit in the Yeti.
09-05-2015, 11:52 PM | #12 |
No way a 5th scale would fit. A standard servo barley fits. Sent from my VS986 using Tapatalk |
09-06-2015, 05:09 AM | #13 |
oh crap I didn't see that, time to pick a new servo. it needs to be waterproof because the Yeti will be seeing a lot of snow.
09-06-2015, 06:52 AM | #14 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
7954 is what I run. No matter what servo you run you'll get ice where the servo is to lock it up. Sent from the future |
09-06-2015, 06:53 AM | #15 |
Again, I'd suggest vanquish front end parts rather than GPM. Better fitting. Sent from the future |
09-06-2015, 03:38 PM | #16 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Xpert wr 7701 is waterproof. Like everyone said vanquish or at least hot racing over gpm/integy. |
09-06-2015, 05:48 PM | #17 |
| Re: opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti |
09-06-2015, 05:48 PM | #18 |
hot racing is better than integy in most areas.
09-07-2015, 08:08 AM | #19 |
I based my aluminum choices in part based on this personal review; Any of you guys running any generic aluminum parts? , but also on what that part does, and what kind of forces it will be taking. Is it more show than go?? then I think that I will take my chances on a less expensive part. If it breaks then I can upgrade it and accept the financial loss but more importantly be able to report on it's short coming first hand. I greatly value and utilize advice from others with first hand experience , BUT Third hand 'Bob said that Tom said that he heard Rob say that he saw a picture of a broken brand x part' really does nothing to help anyone and in fact hurts by limiting the choices and allowing the 'peoples choice' brand to possibly and unnecessarily raise their prices. Now with all of this being said I also believe that if there is an overwhelming consensus that 'part x' is in fact a bad choice then I will will steer clear of it. |
09-07-2015, 10:05 AM | #20 |
Yeti 2.0, Kit or RTR?
opinions? HOT-RACING YET48G01 Aluminum Graphite Steering Bellcrank AXI Yeti - Similar Threads | ||||
Hot Racing BellCrank Fried Servo after 5 min | themacguru1 | Axial Yeti XL | 5 | 03-31-2015 12:45 PM |
Hot Racing Aluminum HC Steering Knuckles WRA21M01 | theidealbarber | Axial Wraith | 8 | 02-12-2012 11:12 PM |
Hot Racing Aluminum Steering links?? | mcap | Axial Wraith | 7 | 01-22-2012 03:48 PM |
GH Racing by Golden Horizons - *NEW* Steering Bellcrank | GH Racing | Vendors Miscellaneous | 0 | 02-11-2008 07:41 PM |
