10-16-2015, 07:43 PM | #1 |
Newbie Join Date: Aug 2015 Location: Milwaukee
| underdrive vs overdrive gears
I was looking through the Yeti manual for information on the over/underdrive gears. I notice that it says for more speed you would use the underdrive gears. Is this true? I thought the overdrive gears would give a little more speed than the underdrive. Also, which gears are better?
10-16-2015, 07:48 PM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: spokane
| Re: underdrive vs overdrive gears
Must be a miss print.
10-16-2015, 08:40 PM | #3 |
RCC Addict Join Date: Aug 2012 Location: Philippines
Underdrive gears are known to have better mesh.
10-16-2015, 09:00 PM | #4 |
I thought it was a little strange that the underdrive gears would give a higher top speed.
10-16-2015, 09:14 PM | #5 |
Rock Stacker Join Date: Jun 2014 Location: Ontario, Canada
I've been running overdrive gears pretty much since the beginning. No problems yet.
10-17-2015, 11:29 AM | #6 |
It's not about the gear ratio, it's about the durability of having a better gear mesh.
10-18-2015, 08:30 AM | #7 |
Quarry Creeper Join Date: Feb 2015 Location: Florida
I hear people say the underdrive gear set has the better gear mesh, but wouldn't a pinion with more teeth on the ring gear have better mesh like the 36/14 overdrive gears?
10-18-2015, 09:28 AM | #8 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
| Re: underdrive vs overdrive gears |
10-18-2015, 12:19 PM | #9 | |
| Re: underdrive vs overdrive gears Quote: | |
10-18-2015, 01:05 PM | #10 |
Pebble Pounder Join Date: Aug 2015 Location: Jackson
I too run the underdrive gears front and rear after stripping the stock kit gears.. No problems since.. Fingers crossed!!!
10-18-2015, 01:29 PM | #11 |
Newbie Join Date: Sep 2009 Location: Maple Ridge, BC
If it is anything like 1:1, different ratios have different angles. You also end up with thicker and thinner pinions. On top of all that, you have more or less torque multiplication. |
underdrive vs overdrive gears - Similar Threads | ||||
Axial gears (overdrive/underdrive) | natskiboy | General Crawlers | 7 | 11-19-2015 04:27 AM |
UnderDrive and OverDrive Gears???? | AsILayDying | Axial SCX-10 | 79 | 09-13-2014 07:46 PM |
No more underdrive or overdrive gears? | C_Money | General Crawlers | 21 | 07-07-2011 11:54 AM |
